Home » Modeling » TMF (Xtext) » Accessing context menu in Xtend IDE locks up computer
Accessing context menu in Xtend IDE locks up computer [message #1205825] Sat, 23 November 2013 15:50 Go to next message
I have an unresolved cross reference which generates a small red "X" in the left margin. When I click on this, the computer gets stuck for several minutes or until I can kill Eclipse via the Process Viewer (which takes several tries). opy/paste likewise! Productivity approaching zero.
I am seeing this in the error log:
!MESSAGE org.eclipse.xtext.ui.editor.model.DocumentPartitioner - Detected unexpected state in document partitioner. Please file a bug...
Where should I file a bug?
I would like to reinstall Xtext/Xtend, but I don't see any straightforward way to do this. It used to work pretty well. Now it doesn't.
GW
[Updated on: Sat, 23 November 2013 16:02] by Moderator
Re: Accessing context menu in Xtend IDE locks up computer [message #1206227 is a reply to message #1205825] Sat, 23 November 2013 20:26 Go to previous messageGo to next message
I completely replaced Eclipse, and it still happens. I also get this error:
eclipse.buildId=4.3.0.M20130905-0705
java.version=1.7.0_45
Framework arguments: -product org.eclipse.epp.package.dsl.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.dsl.product
Error
Sat Nov 23 16:55:15 PST 2013
Unable to find Action Set: org.eclipse.emf.facet.common.editor.actionSet
Re: Accessing context menu in Xtend IDE locks up computer [message #1213304 is a reply to message #1206227] Wed, 27 November 2013 02:22 Go to previous messageGo to next message
Bug reports go here : http://goo.gl/E2NbAh
Please open the error log view and attach the exception stack trace. Also the File you are experiencing the problem with would be helpful.
Thank you!
Sven
Re: Accessing context menu in Xtend IDE locks up computer [message #1214384 is a reply to message #1213304] Wed, 27 November 2013 12:23 Go to previous messageGo to next message
Hi Sven,
Thanks for the info. I was not able to reproduce the Document Partioner issue. The missing ActionSet issue seems to have been solved this morning by adding org.eclipse.ui as an imported package. How it got removed is anyone's guess, but I'll take responsibility. My problems started with that update to Avast anti-virus version 9 and I probably messed a bunch of things up while trying to discover what that issue was.
I've made an entry on my blog about this, though it simply reiterates what I've already said.
http://holycityaudio.com/2013/11/27/missing-actionset/
I have some new problems now but I will work on them for awhile before posting here.
GW
Re: Accessing context menu in Xtend IDE locks up computer [message #1219085 is a reply to message #1214384] Sun, 01 December 2013 10:36 Go to previous message
Solution: start over!
http://www.eclipse.org/forums/index.php/mv/msg/623519/1219024/#msg_1219024
Previous Topic:Two DSLs in one Eclipse project, only one is active
Next Topic:Can't manage to set breakpoints
Current Time: Tue Oct 28 17:03:27 EDT 2025
Powered by FUDForum. Page generated in 0.04428 seconds
