Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Texo] Unset value/Update query
Re: [Texo] Unset value/Update query [message #1200978 is a reply to message #1200807] |
Thu, 21 November 2013 14:08 |
Hi Bastian,
Is the value set back to the original value by Texo on the server side or by EMF on the client side?
There is special EMF behavior that if you set an efeature to null it will return its default value when doing eGet
(which Texo does). So then the default value gets saved on the server. It should work fine as you have EDoubleObject
which should support nulls, but still, can you check?
One other thing which can happen is that Texo on the client side thinks that the value is not set and does not send
anything to the server. So the json send to the server does not contain the changed efeature. Can you check that?
gr. Martin
On 11/21/2013 01:22 PM, Bastian Wagenfeld wrote:
> Hi Martin,
> I've got a problem while unsetting a value. I want to set a double value (in EMF EDoubleObject, in DB double) to null.
> This works as long as I don't save the resource. Then the value gets reverted to the originally set value.
> To avoid this, I created an update query on the resource to set the attribute null. But I got this exception:
> java.lang.IllegalStateException: You cannot call getResultList() on this query. It is the incorrect query type.
> Of course, this makes sense. Is there any possibility to unset this value, either by unsetting it directly or by
> executing a query?
> Best regards
> Bastian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] Unset value/Update query [message #1202555 is a reply to message #1202488] |
Fri, 22 November 2013 07:42 |
Hi Bastian,
Ok, but looking at the code it should do it, can you debug into the BaseModelJSONConverter in the
convertSingleEAttribute method. There the value is retrieved from the EMF object and put in the jsonobject.
Does it get there in your case for this eattribute?
gr. Martin
On 11/22/2013 07:57 AM, Bastian Wagenfeld wrote:
> Hi Martin,
> it is almost like you supposed at last: The changed object is added to the "eObjectsToUpdate" list. At this place the
> attribute is null. But the json-String on the server side does not even contain the attribute, neither the attribute nor
> its value (null).
> Best regards
> Bastian
The Netherlands
Re: [Texo] Unset value/Update query [message #1202710 is a reply to message #1202660] |
Fri, 22 November 2013 09:24 |
Ha, yes I think so, there is a JSONObject.NULL which I guess I can use.
Will try that.
gr. Martin
On 11/22/2013 09:53 AM, Bastian Wagenfeld wrote:
> the value is null and the propName is set correctly. The toJSON method of the JSONValueConverter returns null since none
> of the conditions is true. So the put method of the JSONObject is invoked with the correct key and null. The JSONObject
> code looks like that:
> public JSONObject put(String key, Object value) throws JSONException {
> if (key == null) {
> throw new NullPointerException("Null key.");
> if (value != null) {
> testValidity(value);
> this.map.put(key, value);
> } else {
> this.remove(key);
> return this;
> The value is null, so this.remove(key) is called.
> Is there a possibility to avoid this?
> Bastian
The Netherlands
Re: [Texo] Unset value/Update query [message #1205611 is a reply to message #1202710] |
Sat, 23 November 2013 18:19 |
Hi Bastian,
I published a new build which should solve this.
gr. Martin
> Will try that.
> gr. Martin
>> Hi,
>> if (key == null) {
>> } else {
>> this.remove(key);
>> return this;
>> Bastian
The Netherlands
Current Time: Fri Apr 26 20:54:21 GMT 2024
Powered by FUDForum. Page generated in 0.03103 seconds
