update attributes of class programmatically [message #1198446] |
Wed, 20 November 2013 10:25 |
Kostas Triantafyllidis Messages: 15 Registered: November 2012 |
Hello all,
I am working in uml converting a model from xmi to uml-MARTE compatible. Of course this is done programmatically. I have already managed to create the model, the required classes and the operations that are inside the classes. The operations inside the classes are stereotyped with the "saStep" stereotype. I would like to update the values of some properties of this stereotype. I am trying to use the method setValue(Stereotype, "name_of_property", value), but this returns an exception.
//load subProfile SAM
Profile subprofile_SAM = diagram.getSubProfile(MARTE.getNestedPackage("MARTE_AnalysisModel"), "SAM");
System.out.println(subprofile_SAM);
Stereotype saStep = subprofile_SAM.getOwnedStereotype("SaStep");
org.eclipse.uml2.uml.Class new_class = diagram.createClass(swComponent.NameOfSWComponent);
for(int i=0; i<swComponent.SWComponent.size(); i++)
org.eclipse.uml2.uml.Operation tmp = diagram.createOwnedOperation(swComponent.SWComponent.get(i).OperationMetricsForAllPlatforms.get(0).NameOfOperation, new_class);
tmp.setValue(saStep, "L1CacheMiss", 1000);
The exception that i am receiving looks like this. Do you ave any idea why this is happening? I have to say that the property "L1CacheMiss" exists into the saStep stereotype and i can get its name by tmp.getAppliedStereotypes().get(0).getAllAttributes().get(cnt).getName();.
Exception in thread "main" java.lang.IllegalArgumentException: 1000
at org.eclipse.uml2.uml.internal.operations.ElementOperations.setValue(ElementOperations.java:841)
at org.eclipse.uml2.uml.internal.impl.ElementImpl.setValue(ElementImpl.java:306)
at loadPerformanceModels.files.main.create_OperationsClass(main.java:112)
at loadPerformanceModels.files.main.main(main.java:37)
Thank you in advance for you time,
Kostas
[Updated on: Thu, 21 November 2013 15:34] Report message to a moderator
FUDForum. Page generated in 0.02393 seconds
