Home » Eclipse Projects » Remote Application Platform (RAP) » Bug with fix contributed hasn't made it into code base in two years
Bug with fix contributed hasn't made it into code base in two years [message #1197504] Tue, 19 November 2013 18:32 Go to next message
I wonder if a RAP committer could look into this bug which seems to have fallen through the cracks.
A fix was uploaded to bugzilla two years ago, but it hasn't yet made it into the code base. I discovered the bug in RAP 1.5, but a comment in the bug thread says it's still not fixed in RAP 2.1. Was it perhaps fixed in one of the RAP 2.2 milestones? If not, can it be included in an upcoming release?
It's a simple fix, but I ran into problems trying to build RCP products with a patched version of SWT in the past. There was a mysterious problem with PDE build that we were unable to resolve. We're using Maven now, so maybe we would fare better, but I'm not keen to try it. Without the fix, DeferredTreeContentManagers are not usable in RAP.
[Updated on: Tue, 19 November 2013 18:35] by Moderator
Re: Bug with fix contributed hasn't made it into code base in two years [message #1198140 is a reply to message #1197504] Wed, 20 November 2013 01:58 Go to previous messageGo to next message
Hi Mark,
did you tested the attached to the bug patch? Does it fix the problem?
Best,
Ivan
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=364661 which seems to
> to try it. Without the fix, DeferredTreeContentAdapters are not usable
> in RAP.
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Bug with fix contributed hasn't made it into code base in two years [message #1199483 is a reply to message #1198140] Wed, 20 November 2013 16:42 Go to previous messageGo to next message
Hi Ivan,
I tested the patch you submitted in bugzilla, not the one submitted by the OP. It required two small changes to make it work, and it works properly in my app as modified. I created a patch file and will attach that to the bugzilla entry. I've pasted it below as well. My patch is relative to the code as modified by your patch, so you can see the two extra things I found necessary. It may be that my solution needs to be modified, but I think you can see from the patch the problem that I ran into.
On line 394 (after my patch applied) I added the display instance you created to the WorkbenchJob constructor. Otherwise the WorkbenchJob used a display that had no session context, and it threw an exception. A WorkbenchJob is also created in addChildren(), but this method was always called in the UI thread during my testing, while runClearPlaceholderJob() was not. Do you think anything needs to be done in addChildren()?
On line 230, I added code to make the call to IDeferredWorkbecnhAdapter#fetchDeferredChildren run on the UI thread. My implementation of IDeferredWorkbecnhAdapter is declared in plugin.xml so it has a no-argument constructor. I was therefore unable to give it a reference to a Display instance, and the only way I can get it to work in RAP then is to have the DeferredTreeContentManager call the adapter's method in the UI thread. Perhaps there's a better way to deal with that.
diff --git a/org/eclipse/ui/progress/DeferredTreeContentManager.java b/org/eclipse/ui/progress/DeferredTreeContentManager.java
index 2b89595..ed9b07e 100644
--- a/org/eclipse/ui/progress/DeferredTreeContentManager.java
+++ b/org/eclipse/ui/progress/DeferredTreeContentManager.java
@@ -226,8 +226,14 @@ public class DeferredTreeContentManager {
                         * @see org.eclipse.core.jobs.Job#run(org.eclipse.core.runtime.IProgressMonitor)
-                       public IStatus run(IProgressMonitor monitor) {
-                               adapter.fetchDeferredChildren(parent, collector, monitor);
+                       public IStatus run(final IProgressMonitor monitor) {
+                               display.asyncExec(new Runnable() {
+                                       public void run() {
+                                               adapter.fetchDeferredChildren(parent, collector, monitor);
                                if (monitor.isCanceled()) {
                                        return Status.CANCEL_STATUS;
@@ -385,7 +391,7 @@ public class DeferredTreeContentManager {
                // Clear the placeholder if it is still there
-               WorkbenchJob clearJob = new WorkbenchJob(
+               WorkbenchJob clearJob = new WorkbenchJob(display,
                                ProgressMessages.get( display ).DeferredTreeContentManager_ClearJob) {
                         * (non-Javadoc)
Re: Bug with fix contributed hasn't made it into code base in two years [message #1200500 is a reply to message #1199483] Thu, 21 November 2013 04:12 Go to previous messageGo to next message
Hi Mark,
see my comments below:
Agree with this. I think that adding the display to the second use of
WorkbenchJob (in addChildren()) will not hurt. The session display and
the display provided from outside are the same if you run this coded
from the UI thread.
Why do you need a reference to the display in your implementation. Is it
enough to execute the code with fake context like:
RWT.getUISession( display ).exec( new Runnable() {
public void run() {
instead asynExec?
Best,
Ivan
Ivan Furnadjiev
Re: Bug with fix contributed hasn't made it into code base in two years [message #1200532 is a reply to message #1199483] Thu, 21 November 2013 04:33 Go to previous messageGo to next message
.... small addition... According to
IDeferredWorkbenchAdapter#fetchDeferredChildren JavaDoc:
"Called by a job run in a separate thread to fetch the children of this
adapter."
Your change to run it in UI thread violates it.
Best,
Ivan
> Hi Ivan,
> ran into.
> * @see
> monitor) {
> * (non-Javadoc)
Ivan Furnadjiev
Re: Bug with fix contributed hasn't made it into code base in two years [message #1201090 is a reply to message #1200532] Thu, 21 November 2013 10:19 Go to previous messageGo to next message
Thanks for your help, Ivan. I'll have to find a way to get a Display reference in my IDeferredWorkbenchAdapter implementation. I'm currently on RAP 1.5, so I can't use
RWT.getUISession(display)
to get a reference to the Display. Is the Display stored in a session attribute so that I could retrieve it as follows in RAP 1.5?
RWT.getSessionStore().getAttribute(someKey)
If not, I'll have to find a way to pass the Display into the cosntructor, and I'll probably also have to make the adapter a session singleton.
As far as the fix needed to the RAP code base, it looks like just adding the Display reference to the WorkbenchJob constructor in addChildren() and runClearPlaceholderJob() is all that's needed. Please note that line 382 of DeferredTreeContentManager in your proposed patch seems to be unnecessary. A method-scoped reference to treeViewer's display is created in that line, but there is an instance-scoped reference assigned in the constructor.
Are you planning to submit the patch as amended here, and if so do you have any idea what version or milestone it will be appear in? I pasted a patch below that adds the two changes we agreed on here to your original proposed patch, this time relative to the original code base. However, please note that this is based on RAP 1.5, so a different patch may be needed to apply to a RAP 2.x baseline.
diff --git a/org/eclipse/ui/internal/progress/ProgressMessages.java b/org/eclipse/ui/internal/progress/ProgressMessages.java
index feb1607..d390163 100644
--- a/org/eclipse/ui/internal/progress/ProgressMessages.java
+++ b/org/eclipse/ui/internal/progress/ProgressMessages.java
@@ -11,6 +11,8 @@
 package org.eclipse.ui.internal.progress;
 import org.eclipse.rwt.RWT;
+import org.eclipse.rwt.lifecycle.UICallBack;
+import org.eclipse.swt.widgets.Display;
 // RAP [fappel]: NLS needs to be session/request aware
 //public class ProgressMessages extends NLS{
@@ -138,4 +140,14 @@ public class ProgressMessages {
       Object result = RWT.NLS.getISO8859_1Encoded( BUNDLE_NAME, clazz );
       return ( ProgressMessages )result;
+    public static ProgressMessages get( Display display ) {
+      final ProgressMessages[] result = { null };
+      UICallBack.runNonUIThreadWithFakeContext( display, new Runnable() {
+          result[ 0 ] = get();
+      return result[ 0 ];
index 9cb9f57..8b93168 100644
@@ -41,6 +41,9 @@ import org.eclipse.ui.model.IWorkbenchAdapter;
+// RAP [if] display used to access NLS messages
+    private final Display display;
 	AbstractTreeViewer treeViewer;
 	IWorkbenchSiteProgressService progressService;
@@ -129,6 +132,7 @@ public class DeferredTreeContentManager {
 	public DeferredTreeContentManager(AbstractTreeViewer viewer) {
 		treeViewer = viewer;
+		display = treeViewer.getControl().getDisplay();
@@ -145,7 +149,7 @@ public class DeferredTreeContentManager {
 	public boolean mayHaveChildren(Object element) {
 		Assert.isNotNull(element,
-				ProgressMessages.get().DeferredTreeContentManager_NotDeferred);
+				ProgressMessages.get( display ).DeferredTreeContentManager_NotDeferred);
 		IDeferredWorkbenchAdapter adapter = getAdapter(element);
 		return adapter != null && adapter.isContainer();
@@ -316,7 +320,7 @@ public class DeferredTreeContentManager {
 	protected String getFetchJobName(Object parent,
 			IDeferredWorkbenchAdapter adapter) {
 		return NLS.bind(
-				ProgressMessages.get().DeferredTreeContentManager_FetchingName,
+				ProgressMessages.get( display ).DeferredTreeContentManager_FetchingName,
 				adapter.getLabel(parent));
@@ -329,8 +333,8 @@ public class DeferredTreeContentManager {
 	protected void addChildren(final Object parent, final Object[] children,
-		WorkbenchJob updateJob = new WorkbenchJob(
-				ProgressMessages.get().DeferredTreeContentManager_AddingChildren) {
+		WorkbenchJob updateJob = new WorkbenchJob(display,
+				ProgressMessages.get( display ).DeferredTreeContentManager_AddingChildren) {
 			 * (non-Javadoc)
@@ -375,14 +379,13 @@ public class DeferredTreeContentManager {
 //		if (placeholder.isRemoved() || !PlatformUI.isWorkbenchRunning()) {
 //			return;
-        Display display = treeViewer.getControl().getDisplay();
         if (placeholder.isRemoved() || !ProgressUtil.isWorkbenchRunning( display )) {
 			return;
-				ProgressMessages.get().DeferredTreeContentManager_ClearJob) {
+				ProgressMessages.get( display ).DeferredTreeContentManager_ClearJob) {
 			 * (non-Javadoc)
Re: Bug with fix contributed hasn't made it into code base in two years [message #1201225 is a reply to message #1201090] Thu, 21 November 2013 11:35 Go to previous message
Hi Mark,
I fixed it in master with commit [1]. Fetching children stays the same -
executed in background thread. You still have to find a way how to
obtain a display reference in your IDeferredWorkbenchAdapter implementation.
[1]
http://git.eclipse.org/c/rap/org.eclipse.rap.git/commit/?id=f8a286b305cd65959c562767120fabd017255783
Best,
Ivan
> RWT.getUISession(display) to get a reference to the Display. Is the
> follows in RAP 1.5? RWT.getSessionStore().getAttribute(someKey)
> singleton.
> @@ -11,6 +11,8 @@
> Runnable() {
> +// RAP [if] display used to access NLS messages + private final
> Display display;
> return NLS.bind(
> children,
> * (non-Javadoc)
> * @@ -375,14 +379,13 @@ public class
> // return;
> return;
> * (non-Javadoc)
Ivan Furnadjiev
Previous Topic:Adding an AWT frame to SWT with example
Next Topic:Automated File Upload
Current Time: Tue Jul 29 02:11:46 EDT 2025
Powered by FUDForum. Page generated in 0.25705 seconds
