New Eclipse Tutorial [message #191280] |
Wed, 16 May 2007 20:45  |
You may be interested in the latest update to my tutorial "Using Open
Source Tools for AT91SAM7 Cross Development - Revision C" that was
published on the Atmel AT91 support web site yesterday.
Go to the Atmel web site: www.at91.com
The new revision to the tutorial is in the "Documents" section. There's a
zip file named "atmel_tutorial_source.zip" that has the pdf of the
tutorial, some OpenOCD configuration files and several sample Eclipse
projects.
This revision is a nearly complete rewrite that includes:
1. Use of the Atmel SAM-ICE and the Segger J-Link GDB Server fully
integrated throughout the document.
2. Screenshots compatible with the latest release of YAGARTO and OpenOCD
(as of a few days ago).
3. More explanatory material on the development system in general and how
all the tools work together.
4. Additional material on use of the Eclipse editor.
5. Explanation on the proper use of libraries and examples of such usage
added to the sample projects.
6. Improvement and simplifications to using OpenOCD to program the onchip
flash.
7. Improved debugger start-up procedures.
This tutorial is now at 198 pages and continues to be targeted for the
novice audience. If you are a experienced embedded software designer and
familiar with the GNU tool chain, then the shorter Atmel application note
"GNU-Based Software Development on AT91SAM Microcontrollers:" may be more
appropriate. Also remember that Michael Fischer has many short tutorials
on using YAGARTO and Eclipse on his web site so make sure you check them
out also. http://www.yagarto.de/
I welcome feedback on this article and have encorporated many suggestions
sent to me by interested readers into this new revision.
This is an open source project and in that spirit I have not accepted any
renumeration for my work. I do greatly appreciate Atmel's willingness to
publish it on their web site.
James P. Lynch
Re: New Eclipse Tutorial [message #207295 is a reply to message #191280] |
Fri, 28 December 2007 12:34  |
Originally posted by: reply.to.newsgroup.nospam.no
On Thu, 17 May 2007 00:45:22 +0000 (UTC), lynch007@gmail.com (James P.
>projects.
Good afternoon, James.
I can't find that file anywhere on the atmel website. I found a
3-page application note that references it, but that's about it.
Has it been moved since you posted this note?
Thanks...
FUDForum. Page generated in 0.03293 seconds
