Home » Eclipse Projects » GEF » REQ_DELETE_DEPENDANT
REQ_DELETE_DEPENDANT [message #189934] Mon, 01 August 2005 07:23 Go to next message
Originally posted by: sidney.lee.ibs.net
Hi!
Didn't get a response to this
news://news.eclipse.org:119/42E10BE8.9070103@ibs.net so I thought I
would repost it here:
I would like to adjust the constraints of siblings after a component has
been resized or deleted. For *resize*, I have implemented
getResizeChildrenCommand(ChangeBoundsRequest) in my XYLayoutEditPolicy -
which works perfectly. Now I would like to do the same for *delete*
using getDeleteDependantCommand(Request) since, according to the
documentation for ConstrainedLayoutEditPolicy and REQ_DELETE_DEPENDANT,
"complex layouts may decide to adjust the constraints of the remaining
children". My problem is that I can't seem to get a REQ_DELETE_DEPENDANT
when I delete a component and seem only to be able to delete anything if
I have a ComponetEdiPolicy implement createDeleteCommand and have it
installed for the COMPONENT_ROLE.
Any suggestion?
Many Thanks (as always)!
Re: REQ_DELETE_DEPENDANT [message #190429 is a reply to message #189934] Wed, 03 August 2005 14:43 Go to previous messageGo to next message
Originally posted by: none.unknown.com
When the child editpart gets the delete request, convert it to a delete
dependent request and forward it to the parent editpart.
"Sidney Lee" <sidney.lee@ibs.net> wrote in message
news:dcl0kn$eif$1@news.eclipse.org...
> Hi!
> Any suggestion?
Re: REQ_DELETE_DEPENDANT [message #190505 is a reply to message #190429] Thu, 04 August 2005 05:56 Go to previous messageGo to next message
Hi Pratik!
When u say 'the child editpart gets the delete request convert it
[there]', where exactly would that be - when getCommand() is called on
the child editpart or? And how do I forward it to the parent? (Have a
similar problem where the result from a call to the XYLayoutEditPolicy
method showLayoutTargetFeedback() would also determine whether I need to
forward a REQ_ADD to the parent...)
Thanks, again! Always appreciative.
>>Hi!
>>Any suggestion?
Re: REQ_DELETE_DEPENDANT [message #190625 is a reply to message #190505] Fri, 05 August 2005 01:25 Go to previous messageGo to next message
You can do it in either EditPart#getCommand() or your EditPolicy, whatever
you deem best. I think the former would be the way to go. As for
converting the request, you should be able to just change its type to
REQ_DELETE_DEPENDANT. If not, then just create a new request as expected
and copy the necessary info from the original request. To forward to
parent:
return getParent().getCommand(newRequest);
OR
return getHost().getParent().getCommand(newRequest());
news:42F1E661.7060505@ibs.net...
> Hi Pratik!
> >>Hi!
> >>Any suggestion?
Re: REQ_DELETE_DEPENDANT [message #190632 is a reply to message #190625] Fri, 05 August 2005 04:46 Go to previous message
Thanks, Pratik! Actually, just looked at what was done in the
org.eclipse.gef.editpolicies.ComponentEditPolicy and the
getOrphanCommand() and applied the same approach to the
getDeleteCommand() in my ComponentEditPolicy subclass.
> parent:
> OR
>>Hi Pratik!
>>>>Hi!
>>>>Any suggestion?
Previous Topic:Problem with command line update manager
Next Topic:How to use "ToggleSnapToGeometryAction"
Current Time: Mon Oct 27 11:08:19 EDT 2025
Powered by FUDForum. Page generated in 0.53064 seconds
