Home » Language IDEs » ServerTools (WTP) » servlet api docs/sources
Re: servlet api docs/sources [message #189837 is a reply to message #189781] |
Thu, 15 March 2007 13:55 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
In the Package Explorer (not Project Explorer), right-click on the
jsp-api.jar or servlet-api.jar under the Tomcat Library for a project
and select Properties. You can set the javadoc or source location in
that dialog. I believe this information is cached, so it will appear in
new Dynamic Web projects using the same Tomcat runtime. I forget what
happens with other existing web projects linked to the same Tomcat runtime.
Larry
Zohar wrote:
> Using WTP 2.0 M5, how can I access the servlet API's docs/sources? When
> I configure my tomcat 5.5. as a server, all it's libraries are put under
> a single Library group (this is probably the wrong term, but you
> probably get my drift), but the javadocs/sources are not attached, and I
> couldn't find how to do it myself explicitly. How do I do this?
Re: servlet api docs/sources [message #190078 is a reply to message #189837] |
Sun, 18 March 2007 12:30 |
Zohar Amir Messages: 419 Registered: July 2009 |
ANy idea why the javadoc isn't picked up automatically (when it's in the
standard location)?
"Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
news:etbj82$c6e$2@utils.eclipse.org...
> jsp-api.jar or servlet-api.jar under the Tomcat Library for a project and
> select Properties. You can set the javadoc or source location in that
> dialog. I believe this information is cached, so it will appear in new
> Dynamic Web projects using the same Tomcat runtime. I forget what happens
> Cheers,
> Larry
> Zohar wrote:
>> Hi,
>> Using WTP 2.0 M5, how can I access the servlet API's docs/sources? When I
>> configure my tomcat 5.5. as a server, all it's libraries are put under a
>> single Library group (this is probably the wrong term, but you probably
>> get my drift), but the javadocs/sources are not attached, and I couldn't
Re: servlet api docs/sources [message #190092 is a reply to message #190078] |
Mon, 19 March 2007 13:04 |
I'm not sure what "standard location" you are referring to.
> standard location)?
>> in new Dynamic Web projects using the same Tomcat runtime. I forget
>> what happens with other existing web projects linked to the same
>> Tomcat runtime.
>> Cheers,
>> Larry
>> Zohar wrote:
>>> Hi,
>>> When I configure my tomcat 5.5. as a server, all it's libraries are
>>> put under a single Library group (this is probably the wrong term,
>>> but you probably get my drift), but the javadocs/sources are not
>>> attached, and I couldn't find how to do it myself explicitly. How do
>>> I do this?
Re: servlet api docs/sources [message #190101 is a reply to message #190092] |
Mon, 19 March 2007 14:30 |
$CATALINA_HOME\webapps\tomcat-docs\servletapi
news:etm1pi$ke3$1@utils.eclipse.org...
>> standard location)?
>>> runtime.
>>> Cheers,
>>> Larry
>>> Zohar wrote:
>>>> Hi,
>>>> under a single Library group (this is probably the wrong term, but you
>>>> I couldn't find how to do it myself explicitly. How do I do this?
Re: servlet api docs/sources [message #190109 is a reply to message #190101] |
Mon, 19 March 2007 16:20 |
Feel free to file an enhancement request. Something could be done,
though currently the same code is shared by all versions of Tomcat and
this javadoc location varies somewhat per version. This javadoc isn't
currently included in Tomcat 6.0.x.
Larry
>>> the standard location)?
>>>> project and select Properties. You can set the javadoc or source
>>>> location in that dialog. I believe this information is cached, so
>>>> it will appear in new Dynamic Web projects using the same Tomcat
>>>> runtime. I forget what happens with other existing web projects
>>>> Cheers,
>>>> Larry
>>>> Zohar wrote:
>>>>> Hi,
>>>>> do I do this?
Current Time: Fri Apr 26 04:50:35 GMT 2024
Powered by FUDForum. Page generated in 0.02787 seconds
