Re: JSP validation and Struts tags [message #189575 is a reply to message #189381] |
Sun, 11 March 2007 10:17 |
Originally posted by: casper.casper.casper
> The problem is that the WTp JSP validator issues an error with "foo can
> not be resolved".
I have this same problem, its with a custom tag I wrote my own, but it
actually is with any tag.
Example, of my JSP:
<dh:mytag id="myvar" .../>
then in my JSP after the tag I put the snippet
<%= myvar %>
the code actually WORKS, but the JSP editor in eclipse says theres an error:
cannot resolve "myvar"
My eclipse version is:
Version: 3.2.2
Build id: M20070212-1330
Web Standard Tools - Web Core
Version: 1.5.3.v200701251933--4hNDDhFfKVFaSL
Build id: 200702082048
Re: JSP validation and Struts tags [message #189611 is a reply to message #189575] |
Mon, 12 March 2007 09:53 |
>> not be resolved".
> Example, of my JSP:
> <%= myvar %>
In both of these cases a TagExtraInfo class needs to be declared
that returns information stating that the id/name attributes end up
creating local Java variables along with the correct scopes. The
JSP editor will attempt to load that class and talk to it, but it
has limitations when doing so, among them that the VM running
Eclipse must be able to read the class file--no running Eclipse with
1.4 and using a tag library compiled for 1.5.
Nitin Dahyabhai
Structured Source Editor
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: JSP validation and Struts tags [message #189789 is a reply to message #189611] |
Thu, 15 March 2007 08:41 |
Originally posted by: nomail.xxxxxxxx.com
I doesnt depend on the JVM version.
I tested this on another IDE with JVM 1.4 and it works correctly.
I think it's some sort of bug or misconfiguration of Eclipse WTP.
Re: JSP validation and Struts tags [message #190217 is a reply to message #189789] |
Wed, 21 March 2007 02:36 |
Actually, in WTP it does depend on the JVM version somewhat--I can't
tell you how other IDEs manage it. Glamoute, is your project's
directory directly under the workspace folder or is it elsewhere?
You might be affected by bug 178443.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=178443
Nitin Dahyabhai
_
Nitin Dahyabhai
FUDForum. Page generated in 0.03395 seconds
