Home » Modeling » GMF (Graphical Modeling Framework) » "Element A" and "Element B" should contain both "Element C"
"Element A" and "Element B" should contain both "Element C" [message #188929] Fri, 23 May 2008 04:42 Go to next message
Originally posted by: romantul.gmail.com
I'm trying to implement a following thing with GMF:
|Element A | |Element B |
||Element C|| ||Element C||
"Element A" and "Element B" should contain the same "Element C" as a
child Node.
In order to do it, the type of "Element A" and "Element B" aggregates
the type of "Element C", so I can define a compartment in the gmfgraph
and compartment mapping gmfmap and so on.
On the diagram I create the "Element A" and the "Element C" inside it.
Then I create "Element B" and set there "Element C" in the Properties view.
The Problem is - "Element C" disappears from out of "Element A".
How can I manage this Problem?
Thank you.
Re: "Element A" and "Element B" should contain both "Element C" [message #188936 is a reply to message #188929] Fri, 23 May 2008 05:03 Go to previous messageGo to next message
Originally posted by: gmerin.integranova.com
Hi Tarantul,
That behaviour is normal. That is because an object can only have one
parent. So if you move Element C from A to B, then C is moved phisically
from A. Therefore, when A tries to refresh its Figure, it asks for his
semanticChildren and, as it does have none, then C is not drawn.
Since Ecore only has composite aggregations and no shared aggregations,
you'll have to simulate this behaviour. One way to achive this could be
creating a new Element X who stores a list of Elements C (with an
aggregation). Then, Elements A and B only need a simple Association with
Elements C.
I hope it helps!
Gabriel.
tarantul escribió:
> child Node.
> Thank you.
Re: "Element A" and "Element B" should contain both "Element C" [message #189025 is a reply to message #188936] Fri, 23 May 2008 06:53 Go to previous messageGo to next message
Thank you Gabriel,
I understand this behavior, and I've already tried to make it this way
> Elements C.
"Element C" was then aggregated by the "Diagram" Element and associated
by "Element A" and "Element B".
The resulting problem is then - I can't define any compartments to draw
"C" inside of "A" or "B" as a child element.
This is because of the constrain for defining a compartment of some
element inside one another, there should be an aggregation between them.
Is there maybe another way to solve my problem?
Roman
Re: "Element A" and "Element B" should contain both "Element C" [message #189040 is a reply to message #188936] Fri, 23 May 2008 07:01 Go to previous messageGo to next message
Thank you Gabriel,
> Elements C.
Roman
Gabriel Merin Cubero schrieb:
> Hi Tarantul,
> Elements C.
> I hope it helps!
> Gabriel.
> tarantul escribió:
>> child Node.
>> it. Then I create "Element B" and set there "Element C" in the
>> Properties view.
>> Thank you.
Re: "Element A" and "Element B" should contain both "Element C" [message #189084 is a reply to message #189040] Fri, 23 May 2008 08:20 Go to previous messageGo to next message
If I'm dowing it like this:
Association with
> > Elements C.
I get an error message while generating a Diagram Editor Gen Model (gmfgen):
"'Containment Feature' must be owned ba 'Domanin Meta Element' ... "
Is there another possibility to show nodes inside one another, without
defining a containment?
tarantul schrieb:
> Thank you Gabriel,
> > Elements C.
> Roman
>> Hi Tarantul,
>> phisically from A. Therefore, when A tries to refresh its Figure, it
>> asks for his semanticChildren and, as it does have none, then C is not
>> drawn.
>> aggregations, you'll have to simulate this behaviour. One way to
>> achive this could be creating a new Element X who stores a list of
>> Elements C (with an aggregation). Then, Elements A and B only need a
>> simple Association with Elements C.
>> I hope it helps!
>> Regards,
>> Gabriel.
>> tarantul escribió:
>>> Hi,
>>> child Node.
>>> gmfgraph and compartment mapping gmfmap and so on.
>>> Properties view.
>>> Thank you.
Re: "Element A" and "Element B" should contain both "Element C" [message #189291 is a reply to message #189084] Sat, 24 May 2008 16:17 Go to previous messageGo to next message
As I see it, one element can be shown only once in the diagram. Any other
occurrences are represented as shortcuts. Try to see if you can create a
shortcut to ElementC programatically when it is moved from ElementB to
ElementA.
Or do something like Gabriel suggested. Create a new containment relation
from ElementB to ProxyElementC (let's call it like that), which has an
association to ElementC. You'll define the compartment in ElementB for the
proxy containment relation and the nodes will represent the ProxyElementC
instances and they will use the information from the referred ElementC
instances.
If this doesn't work, make ProxyElementC extend ElementC (also wrapping an
instance of ElementC, and when an ElementC is moved from ElementB to
ElementA, create a ProxyElementC in its place. The compartments will remain
as you have them defined now.
Lucian
Re: "Element A" and "Element B" should contain both "Element C" [message #189351 is a reply to message #189084] Tue, 27 May 2008 05:53 Go to previous messageGo to next message
Hi again,
Unfortunately, the only way to achieve your goal is by handcoding your
behaviour. As you say, a compartment can only show child elements, not
associated elements (by default). But it's not imposible because, for
example, we've done exactly what you are trying to do when showing
referenced columns within a View Table in a DB Diagram.
However, for associations with other elements, I would suggest a custom
property tab instead of compartments because GMF considers compartments
as child containers and if you want to avoid this behaviour you'll have
to change the generated code.
> Association with
> > > Elements C.
> (gmfgen):
> tarantul schrieb:
>> Thank you Gabriel,
>> with
>> > Elements C.
>> associated by "Element A" and "Element B".
>> draw "C" inside of "A" or "B" as a child element.
>> Regards,
>> Roman
>>> Hi Tarantul,
>>> not drawn.
>>> I hope it helps!
>>> Regards,
>>> Gabriel.
>>> tarantul escribió:
>>>> Hi,
>>>> child Node.
>>>> aggregates the type of "Element C", so I can define a compartment in
>>>> the gmfgraph and compartment mapping gmfmap and so on.
>>>> Properties view.
>>>> Thank you.
Re: "Element A" and "Element B" should contain both "Element C" [message #190987 is a reply to message #189351] Wed, 04 June 2008 09:03 Go to previous message
Gabriel, thank you for this answer. Now I at least know, what is
definitely NOT functioning :-) .
> ... . But it's not imposible because, for
I would prefer the solution above. Can you please describe this way more
detailed. For example, what DB Diagram do You mean? Or is there
somewhere a functioning example with this kind of functionality?
Roman
> Hi again,
>> Association with
>> > > Elements C.
>> (gmfgen):
>> tarantul schrieb:
>>> Thank you Gabriel,
>>> Association with
>>> > Elements C.
>>> Regards,
>>> Roman
>>>> Hi Tarantul,
>>>> one parent. So if you move Element C from A to B, then C is moved
>>>> it asks for his semanticChildren and, as it does have none, then C
>>>> is not drawn.
>>>> I hope it helps!
>>>> Regards,
>>>> Gabriel.
>>>> tarantul escribió:
>>>>> Hi,
>>>>> a child Node.
>>>>> in the gmfgraph and compartment mapping gmfmap and so on.
>>>>> Properties view.
>>>>> Thank you.
Previous Topic:Problems with 2.1 RC1 with gmfmap, and gmfgen, null pointers and class cast exceptions
Next Topic:handleNotificationEvent in editpart not called when making a change through an action, what am I doi
Current Time: Fri Nov 07 00:34:05 EST 2025
Powered by FUDForum. Page generated in 0.03949 seconds
