Home » Modeling » GMF (Graphical Modeling Framework) » Removing "Delete from model" action
Removing "Delete from model" action [message #188193] Wed, 21 May 2008 08:27
Hi all,
I would like to remove any "Delete from model" action from the contextual
model.
To achieve this, I have found how to remove them in the extension point
" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders ".
by removing this section for example :
<popupContribution
class=" org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContextM enuProvider ">
<popupStructuredContributionCriteria
objectClass=" fr.itcs.architecture.diagram.edit.parts.ISimObjectClassExten dedISimObjectClassesEditPart "/>
<popupAction path="/editGroup" id="deleteFromModelAction"/>
</popupContribution>
My problem :
- this action still appears when the user selects different kinds of
model element in the diagram.
Is there a way to avoid this ?
Thank you,
Sylvain
Previous Topic:Killing "Core" tab property
Next Topic:changes in templates between versions of GMF ?
Current Time: Tue Sep 23 21:30:48 EDT 2025
Powered by FUDForum. Page generated in 0.03859 seconds
