Re: eclipse WTP + JWSDP + Tomcat [message #188461 is a reply to message #188325] |
Thu, 22 February 2007 05:49 |
Originally posted by: nmahajan.removemenaddeduatend.cse.buffalo
Hi Larry,
By "development environment" I mean an intelligent IDE i.e. something like
eclipse+WTP that would help me develop/build/deploy/debug Web Services. As
you mentioned Tomcat doesnt include Axis runtime, and that is the reasin
why, I think, it can be used with Java WSDP too. But AFAIK WTP includes
Axis runtime to be used with Tomcat. So the question is, can I use WTP to
develop WebServices for Tomcat+WSDP. If yes, then what plugins do I need
to use for this.
Neeraj
PS: The reason for using WSDP is beyond my control :(
Larry Isaacs wrote:
> I'm not sure exactly what you are asking for in the way of a
> "development environment". Tomcat doesn't include a default Axis
> runtime. I assume the Java WSDP would somehow provide that. WTP has
> its own support for developing web services that doesn't involve the
> Java WSDP. Have you investigated this support and decided to use Java
> WSDP instead?
> Cheers,
> Larry
> Neeraj Mahajan wrote:
>> Hi,
>> I am trying to setup eclipse WTP with Java WSDP (1.6) and Tomcat for
>> JWSDP
>> ( http://java.sun.com/webservices/containers/tomcat_for_JWSDP_ 1_5.html)
>> Any idea whether it is possible to have such development environment or
>> would I have to use Netbeans?
>> Wouldn't I require a server runtime for (J)WSDP instead of Tomcat's
>> deault Axis runtime? Is there such a runtime available?
>> Thanks,
>> Neeraj
Re: eclipse WTP + JWSDP + Tomcat [message #188477 is a reply to message #188461] |
Thu, 22 February 2007 13:44 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
I guess you could say that using Tomcat+WSDP in WTP would "work", but
not with the same level of integration that you get using the WTP
supplied Axis. I'm not familiar with JSDP, but I don't think WTP would
get in the way. However, I can't say if it will provide as much
"developmental help" as you are looking for.
Larry
> Hi Larry,
> like eclipse+WTP that would help me develop/build/deploy/debug Web
> Services. As you mentioned Tomcat doesnt include Axis runtime, and that
> is the reasin why, I think, it can be used with Java WSDP too. But AFAIK
> WTP includes Axis runtime to be used with Tomcat. So the question is,
> can I use WTP to develop WebServices for Tomcat+WSDP. If yes, then what
> plugins do I need to use for this.
> Cheers,
> Neeraj
>> WSDP instead?
>> Cheers,
>> Larry
>>> Hi,
>>> JWSDP
>>> or would I have to use Netbeans?
>>> Thanks,
>>> Neeraj
Re: eclipse WTP + JWSDP + Tomcat [message #192246 is a reply to message #188325] |
Tue, 08 May 2007 18:12 |
Originally posted by: user.domain.invalid
Hi Larry I'm having exactly the same problem, I think.
I want to develop with Eclipse 3.2, Tomcat (any version) + JAX-WS 2.0.
I've downloaded WTP and now I can develop with Axis, but I don't want
Axis.......
Any progress?
> WSDP instead?
> Cheers,
> Larry
>> Hi,
>> JWSDP
>> Thanks,
>> Neeraj
FUDForum. Page generated in 0.03861 seconds
