Reconnecting imported packages after file system changes [message #1184376] |
Wed, 13 November 2013 12:03 |
Tomas Sandkvist Messages: 149 Registered: October 2013 |
I'm experimenting with package import and first I created two projects 1 and 2, and added one block in each model.
I created a block diagram in model 2, and imported the model from project 1, and added block 1 to the diagram. Looks good.
Next, I closed both projects, and moved the model in project 1 to a subfolder.
Now, when I open the block diagram in model 2 I can't find any way what so ever to update the block in the diagram to model 1 in its new position in the file system.
Not even by removing the package import and redoing it, the block "feels" that is belongs to the model at its previous position in the root folder of project 1.
Is there a way I don't see, or is this a no-no, restructuring the project to get a more easy to navigate structure after some time when having created an abundance of models?
Tomas Sandkvist
FUDForum. Page generated in 0.03388 seconds
