Bug with WTP 2.0 M4 vs. Eclipse 3.3M5? [message #187885] |
Sun, 11 February 2007 17:58 |
Originally posted by: konigsberg-at-g-m.ail-ddooott.com
This seems to be a serious bug when using WTP 2.0 M4 with Eclipse 3.3M5 (and
nothing else). I have no other plugins installed other than those two, and
the list of dependencies that go with WTP 2.0M4
I created a new JSP file*. When Eclipse tries to display the file, I get the
internal error listed at the end of this message. You may be aware of it,
you may not. Shall I report this as a bug?
* The exact same thing is happening with HTML files as well.
"An SWT error has occured. You are recommended to exit the workbench"...
Here are the contents of the error from the Error Log view:
Message: Unhandled event loop exception
Session Data: eclipse.buildId=I20070209-1006
java.version=1.5.0_08
Framework arguments: -launcher
C:\apps\eclipse\versions\eclipse-SDK-3.3M5-win32\eclipse\ecl ipse.exe -name
Eclipse -startup
C:\apps\eclipse\versions\eclipse-SDK-3.3M5-win32\eclipse\plu gins\org.eclipse.equinox.launcher_1.0.0.v20070208a.jar
Command-line arguments: -os win32 -ws win32 -arch x86 -launcher
Eclipse -startup
Exception Stack Trace:
org.eclipse.swt.SWTError: Cannot initialize Drop
at org.eclipse.swt.dnd.DND.error(DND.java:247)
at org.eclipse.swt.dnd.DND.error(DND.java:208)
at org.eclipse.swt.dnd.DropTarget.<init>(DropTarget.java:130)
at
org.eclipse.ui.internal.EditorSiteDragAndDropServiceImpl$Mer gedDropTarget. <init>(EditorSiteDragAndDropServiceImpl.java:70)
at
org.eclipse.ui.internal.EditorSiteDragAndDropServiceImpl.add MergedDropTarget(EditorSiteDragAndDropServiceImpl.java:157)
at
org.eclipse.ui.texteditor.AbstractTextEditor.installTextDrag AndDrop(AbstractTextEditor.java:3196)
at
org.eclipse.ui.texteditor.AbstractTextEditor.initializeDragA ndDrop(AbstractTextEditor.java:2821)
at
org.eclipse.ui.texteditor.AbstractTextEditor.createPartContr ol(AbstractTextEditor.java:2899)
at
org.eclipse.ui.texteditor.StatusTextEditor.createPartControl (StatusTextEditor.java:53)
at
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.create PartControl(AbstractDecoratedTextEditor.java:373)
at
org.eclipse.wst.sse.ui.StructuredTextEditor.createPartContro l(StructuredTextEditor.java:1771)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:662)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:421)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:586)
at
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:257)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2598)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2524)
at org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2516)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2501)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2496)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2480)
at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu. java:334)
at org.eclipse.ui.actions.OpenWithMenu.access$0(OpenWithMenu.ja va:326)
at org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMe nu.java:190)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3490)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3104)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2264)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2228)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 03)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:457)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:452)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:101)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:146)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:354)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 476)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:416)
at org.eclipse.equinox.launcher.Main.run(Main.java:1124)
Re: Bug with WTP 2.0 M4 vs. Eclipse 3.3M5? [message #187894 is a reply to message #187885] |
Mon, 12 February 2007 11:02 |
Originally posted by: joerg.von.frantzius.artnology.com
<html>
<head>
</head>
I'm getting a similar error for the XML editor on Linux GTK2 86_64:
<blockquote><tt>org.eclipse.swt.SWTError: Cannot initialize Drop<br>
at org.eclipse.swt.dnd.DND.error(DND.java:247)<br>
at org.eclipse.swt.dnd.DND.error(DND.java:208)<br>
at org.eclipse.swt.dnd.DropTarget.<init>(DropTarg et.java:153) <br>
at
org.eclipse.ui.internal.EditorSiteDragAndDropServiceImpl$Mer gedDropTarget.<init>(EditorSiteDragAndDropServ iceImpl.java:70) <br>
at
org.eclipse.ui.internal.EditorSiteDragAndDropServiceImpl.add MergedDropTarget(EditorSiteDragAndDropServiceImpl.java:157) <br>
at
org.eclipse.ui.texteditor.AbstractTextEditor.installTextDrag AndDrop(AbstractTextEditor.java:3196) <br>
at
org.eclipse.ui.texteditor.AbstractTextEditor.initializeDragA ndDrop(AbstractTextEditor.java:2821) <br>
at
org.eclipse.ui.texteditor.AbstractTextEditor.createPartContr ol(AbstractTextEditor.java:2899) <br>
at
org.eclipse.ui.texteditor.StatusTextEditor.createPartControl (StatusTextEditor.java:53) <br>
at
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.create PartControl(AbstractDecoratedTextEditor.java:373) <br>
at
org.eclipse.wst.sse.ui.StructuredTextEditor.createPartContro l(StructuredTextEditor.java:1771) <br>
at
org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEdi torPart.java:185) <br>
at
org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEdi torPart.java:155) <br>
at
org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part.addSourcePage(XMLMultiPageEditorPart.java:336) <br>
at
org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part.createPages(XMLMultiPageEditorPart.java:507) <br>
at
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:278) <br>
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:662) <br>
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:421) <br>
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:586) <br>
at
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:257) <br>
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2598) <br>
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2524) <br>
at
org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2516) <br>
at
org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2501) <br>
at
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67) <br>
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2496) <br>
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2480) <br>
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2471) <br>
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:638)<br>
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:597)<br>
at
org.eclipse.ui.internal.ide.handlers.OpenResourceHandler.exe cute(OpenResourceHandler.java:124) <br>
at
org.eclipse.ui.internal.ide.handlers.OpenResourceHandler.run (OpenResourceHandler.java:176) <br>
at
org.eclipse.ui.internal.handlers.ActionDelegateHandlerProxy. execute(ActionDelegateHandlerProxy.java:267) <br>
at
org.eclipse.core.commands.Command.executeWithChecks(Command. java:471) <br>
at
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:424) <br>
at
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:160) <br>
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchKeyboard.java:467) <br>
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.java:791) <br>
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(WorkbenchKeyboard.java:838) <br>
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(WorkbenchKeyboard.java:565) <br>
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(Work benchKeyboard.java:507) <br>
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter .handleEvent(WorkbenchKeyboard.java:124) <br>
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66) <br>
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:138 6) <br>
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1096)<br >
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1121)<br >
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1106)<br >
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1133 ) <br>
at
org.eclipse.swt.widgets.Widget.gtk_key_press_event(Widget.ja va:663) <br>
at
org.eclipse.swt.widgets.Control.gtk_key_press_event(Control. java:2212) <br>
at
org.eclipse.swt.widgets.Composite.gtk_key_press_event(Compos ite.java:670) <br>
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1478)<br >
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3879 ) <br>
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3870 ) <br>
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)<br>
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:55 74) <br>
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1155) <br>
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Na tive
Method)<br>
at
org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS. java:1468) <br>
at
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2903) <br>
at
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2264) <br>
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2228) <br>
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 03) <br>
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:457)<br >
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289) <br>
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:452) <br>
at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149) <br>
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:101) <br>
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:146) <br>
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106) <br>
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76) <br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:354) <br>
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169) <br>
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)<br>
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39) <br>
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25) <br>
at java.lang.reflect.Method.invoke(Method.java:585)<br>
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 476) <br>
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:416)<br >
at org.eclipse.equinox.launcher.Main.run(Main.java:1124)<br>
at org.eclipse.equinox.launcher.Main.main(Main.java:1099)</tt> <br>
</blockquote>
<br>
Robert Konigsberg wrote:
<blockquote cite="mid:eqnlgj$oi6$1@utils.eclipse.org" type="cite">
<pre wrap="">Hi,
Eclipse -startup
Eclipse -startup
at org.eclipse.swt.dnd.DropTarget.<init>(DropTarg et.java:130)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
</pre>
</blockquote>
<br>
</body>
</html>
FUDForum. Page generated in 0.03069 seconds
