Home » Eclipse Projects » Eclipse Platform » Problems during startup. Check the ".log" file in the ".metadata" directory of y
Problems during startup. Check the ".log" file in the ".metadata" directory of y [message #187705] Sat, 31 January 2004 04:42 Go to next message
Hy,
I just unziped the eclipse 2.1.2 into my /opt directory and tried to sta=
rt =
eclipse. I always get the error message "Problems during startup. Check =
the ".log" file in the ".metadata" directory of your workspace.". But I =
don't have a directory "workspace"!.
What could be wrong here? Has anybody a clue?
thanks and kind regards
Fredy
Re: Problems during startup. Check the ".log" file in the ".metadata" directory [message #187765 is a reply to message #187705] Sat, 31 January 2004 09:04 Go to previous messageGo to next message
On Sat, 31 Jan 2004 10:42:06 +0100, Fredy Klammsteiner <fredy.k@gmx.net>=
wrote:
> Hy,
> I just unziped the eclipse 2.1.2 into my /opt directory and tried to =
> start eclipse. I always get the error message "Problems during startup=
> Check the ".log" file in the ".metadata" directory of your workspace."=
> But I don't have a directory "workspace"!.
> Fredy
The following printout may be a help of experts:
An exception occurred while writing to the platform log:
java.io.FileNotFoundException: /opt/eclipse/workspace/.metadata/.log (No=
such file or directory)
at java.io.FileOutputStream.openAppend(Native Method)
at java.io.FileOutputStream.<init>(FileOutputStream.java:177)
at java.io.FileOutputStream.<init>(FileOutputStream.java:102)
at org.eclipse.core.launcher.Main.openLogFile(Main.java:1400)
at org.eclipse.core.launcher.Main.log(Main.java:1261)
at org.eclipse.core.launcher.Main.main(Main.java:587)
Logging to the console instead.
!ENTRY org.eclipse.core.launcher 4 0 Jan 31, 2004 15:01:09.710
!MESSAGE Exception launching the Eclipse Platform:
at org.eclipse.core.launcher.Main.main(Main.java:588)
!STACK
java.lang.reflect.InvocationTargetException
at =
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.jav=
a:39)
at =
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessor=
Impl.java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Caused by: java.lang.reflect.InvocationTargetException
at =
a:39)
at =
Impl.java:25)
at =
org.eclipse.core.internal.boot.InternalBootLoader.startup(In ternalBootLo=
ader.java:1040)
at =
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader=
..java:838)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
... 7 more
Caused by: org.eclipse.core.runtime.CoreException: The platform metadata=
area could not be written: /opt/eclipse/workspace/.metadata. By default=
the platform writes its content
under the current working directory when the platform is launched. Use =
the -data parameter to
specify a different content area for the platform.
at =
org.eclipse.core.internal.runtime.PlatformMetaArea.createLoc ation(Platfo=
rmMetaArea.java:73)
at =
org.eclipse.core.internal.runtime.InternalPlatform.setupMeta Area(Interna=
lPlatform.java:1053)
at =
org.eclipse.core.internal.runtime.InternalPlatform.loaderSta rtup(Interna=
lPlatform.java:679)
... 14 more
Re: Problems during startup. Check the ".log" file in the ".metadata" directory [message #188420 is a reply to message #187765] Mon, 02 February 2004 14:49 Go to previous messageGo to next message
> wrote:
>> Hy,
>> startup.. Check the ".log" file in the ".metadata" directory of your
>> workspace.".. But I don't have a directory "workspace"!.
>> Fredy
So you're running Eclipse with a user ID that doesn't have write
permission to the /opt/eclipse/ directory. You have to run it using the
-data parameter to specify a directory where your user ID does have
permission to create files; say /home/userID/:
/opt/eclipse/eclipse -data /home/userID
(where userID represents your current user ID).
Dan
Re: Problems during startup. Check the ".log" file in the ".metadata" directory [message #1801650 is a reply to message #187705] Thu, 24 January 2019 01:49 Go to previous message
I have some similar message when trying to run on one of my PC with Windows 10.
However, it runs fine with another Win10 PC.
Managed to trace and capture some message as following:
I have both of my machine setup as same login ID, Chan Chan
Fail machine I get the following:
java.lang.reflect.InvocationTargetException: org.eclipse.core.runtime.CoreException: The platform metadata area could not be written: C:\Users\Chan\.metadata. By default the platform writes its content
On the good machine, it seem the different is on the directory it try to
C:\Users\CHANCH~1\.metadata.
I tried to create another ID on the failed machine, ChanChan (without space in between), and it runs without error. I am not sure where the problem come from?
Previous Topic:RCP config.ini not working since updating to Eclipse 4.9
Next Topic:Code folding bar color?
Current Time: Tue Nov 04 08:46:59 EST 2025
Powered by FUDForum. Page generated in 0.04227 seconds
