| Copy/Paste for compartment items... [message #187621] |
Mon, 19 May 2008 02:34  |
sorry for posting again, but I didn't find the answer.
So, if somebody can help me... I think this feature is very important.
Philippe BLANC
Philippe BLANC a écrit :
> I want to enable copy/paste feature to my diagram (nodes and
compartment).
> I found this post :
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg04918.html
> but I need some explications...
> 1] I have implemented my ClipBoard support and ClipBoard support
factory. If I use nsri =
"http://www.eclipse.org/gmf/runtime/1.0.1/notation" in my plugin.xml
file, just my view is copy/paste (there is no node created in my
semantic model). But, if I use nsri = "http://mySemanticDomainNSRI",
copy/past for nodes work, but my code is never called. Is it normal ?
> 2]Can someboy explain precisly what are the functions to override to
implement copy/paste in compartments ? And explain how to implement them ?
> Thanks for your help.
> Best regards,
> Philippe
> Here is my simple code :
> public class EventBClipboardSupport extends AbstractClipboardSupport {
> @Override
> public boolean isCopyAlways(EObject eObject, EReference eReference,
> Object value) {
> EClass pack = eObject.eClass();
> EClass pack2 = EventBPackage.eINSTANCE.getMachine();
> if (eObject.eClass() == EventBPackage.eINSTANCE.getMachine()
> eObject.eClass() ==
EventBPackage.eINSTANCE.getContext()){
> * Do not copy Refines and IsRefined link.
> if (eReference ==
EventBPackage.eINSTANCE.getMachine_Refines()
> eReference ==
EventBPackage.eINSTANCE.getMachine_IsRefined()
> eReference ==
EventBPackage.eINSTANCE.getContext_Extends()
> eReference ==
EventBPackage.eINSTANCE.getContext_IsExtended())
> return false;
> else
> return true;
> } else
> return super.isCopyAlways(eObject, eReference, value);
> public PasteAction getPasteCollisionAction(EClass eClass) {
> if (eClass == EventBPackage.eINSTANCE.getMachine()) {
> return PasteAction.CLONE;
> } else if (eClass == EventBPackage.eINSTANCE.getContext()) {
> } else {
> return super.getPasteCollisionAction(eClass);
| Re: Copy/Paste for compartment items... [message #188074 is a reply to message #187621] |
Wed, 21 May 2008 01:58  |
Hi Philippe,
i also still struggle with the correct implementation of the
copy/paste-functionality, especially for compartments.
The GMF-generated code provides copy/paste-support for
top-level-elements (with all existing containments), if you enable uuids
in the model file:
1. add
<extension point="org.eclipse.emf.ecore.extension_parser">
<parser
class=" org.eclipse.gmf.runtime.emf.core.resources.GMFResourceFactor y "
type="<YOUR MODEL FILE EXTENSION>">
</parser>
</extension>
Vlad's post
( http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg04918.html)
allows pasting into compartments.
However this solution doesn't persist the compartment-copy in the domain
model file, but in the diagram file as a reference to the source. So if
the source is deleted, the copy is gone as well.
I'm kind of stuck at this moment, because I don't really know where to
go from here.
Has anyone found a further refinement of Vlad's solution?
I think the copy-paste feature is very essential and important for
successful implementations of GMF-products.
Is there any chance, we could get some final support from the
contributers or maybe even an integration with the upcoming 2.1-release?
This would really help a lot, given that there a quiet a few threads
regarding copy/paste in this newsgroup.
Thanks in advance.
Regards Thomas
Philippe BLANC schrieb:
> Philippe BLANC
> > Hi,
> compartment).
> > I found this post :
> > Best regards,
> > Philippe
> > @Override
> > Object value) {
> > eObject.eClass() ==
> > if (eReference ==
> > eReference ==
> > eReference ==
> > eReference ==
> > return false;
> > else
> > return true;
> > } else
> > } else {
FUDForum. Page generated in 0.03498 seconds
