| Adding JBoss runtime configuration from plugin [message #187603] |
Tue, 06 February 2007 10:44  |
How can I can add JBoss runtime configuration from plugin.
Code below creates Runtime configuration, but it does not set add JBoss
root location. As I understand that I should send property
"serverRootDirectory" to configuration bu I didn't way how.
I will very appreciate for any help
Mark
IServerType serverTypeJBoss4 = ServerCore
findServerType("org.eclipse.jst.server.generic.jboss4");
if (serverTypeJBoss4 != null)
IRuntimeType runtimeType = serverTypeJBoss4.getRuntimeType();
if (runtimeType != null)
IRuntimeWorkingCopy runtimeWorkingCopy = runtimeType.createRuntime(
"jboss.runtime", monitor);
runtimeWorkingCopy.setLocation(newPath(jbossHomeDir.getCanon icalPath()));
runtimeWorkingCopy.save(true, monitor);
| Re: Adding JBoss runtime configuration from plugin [message #187644 is a reply to message #187603] |
Wed, 07 February 2007 01:04   |
Below is a code snippet from the junit tests for jonas. It show the way
to add attributes to a generic server. Of course jboss has a different
set of properties.
GenericServerRuntime runtimeDelegate =
(GenericServerRuntime)runtimeWorkingCopy.loadAdapter(Generic ServerRuntime.class,new
NullProgressMonitor());
HashMap props = new HashMap();
props.put("mappernames", "");
props.put("classPathVariableName", "JONAS");
props.put("serverAddress", "127.0.0.1");
props.put("jonasBase", "C:\\JOnAS-4.1.4");
props.put("jonasRoot", "C:\\JOnAS-4.1.4");
props.put("classPath", "C:\\JOnAS-4.1.4");
props.put("protocols", "C:\\JOnAS-4.1.4");
props.put("port", "9000");
runtimeDelegate.setServerInstanceProperties(props);
//Save the runtime working copy
runtimeWorkingCopy.save(false,null);
Gorkem
> Mark
FUDForum. Page generated in 0.03995 seconds
