Re: Creating a web service client [message #186848 is a reply to message #186838] |
Wed, 24 January 2007 15:50 |
Andrew Mak Messages: 41 Registered: July 2009 |
Member |
Hi Zohar,
You can create a client for your service using the Web Service Client
Wizard. Here are the steps to get you started:
1. Click on New > Other... from the menu
2. Look for the Web Services folder and select Web Service Client, click
next (the Web Service Client Wizard comes up).
From here, you can click on browse to select a WSDL that you have
downloaded to your workspace, or you can type in a live URL directly.
Below the service definition field there are a bunch of options that you
can play around with, such as controlling how far the wizard should
proceed (for example, the wizard will generate samples JSPs for testing
the service if the slider is set to the "Test" position); and you can also
set configure the target server and runtime.
If you have anymore questions regarding the options, please don't hesitate
to post on the newsgroup.
Hope this helps.
Andrew
Zohar wrote:
> Hello,
> I have a web service's WSDL and I need to write a client for that service.
> What is the best way to do that?
> Zohar.
Re: Creating a web service client [message #186852 is a reply to message #186848] |
Wed, 24 January 2007 15:58 |
Member |
Hi Zohar,
I forgot to mention, you can also take a look at the following tutorial:
http://www.eclipse.org/webtools/jst/components/ws/1.5/tutori als/WebServiceClient/WebServiceClient.html
Andrew Mak wrote:
> Hi Zohar,
> Hope this helps.
> Andrew
> Zohar wrote:
>> Hello,
>> Thanks,
>> Zohar.
Re: Creating a web service client [message #186870 is a reply to message #186852] |
Wed, 24 January 2007 17:04 |
Zohar Amir Messages: 419 Registered: July 2009 |
I get a bunch of classes created - how do I use them...?
"Andrew Mak" <makandre@ca.ibm.com> wrote in message
news:d5a54eeb6e8eb58a78f6726dc9c67156$1@www.eclipse.org...
> Hi Zohar,
> Andrew Mak wrote:
>> Hi Zohar,
>> also set configure the target server and runtime.
>> hesitate to post on the newsgroup.
>> Hope this helps.
>> Andrew
>> Zohar wrote:
>>> Hello,
>>> service. What is the best way to do that?
>>> Thanks,
>>> Zohar.
FUDForum. Page generated in 0.04739 seconds
