Home » Language IDEs » ServerTools (WTP) » Preventing external loading of xsd
Preventing external loading of xsd [message #186708] Mon, 22 January 2007 08:15 Go to next message
Originally posted by: mllist.mvdb.net
Hi everyone,
I tried to figure out an easy wat to programatically prevent the xml editor from loading my xsd from
an external location, but without any success.
If anyone has any pointers (or preferrably examples), that would be highly appreciated.
Just an FYI : I will have to write a custom xml editor eventually, so a solution/example in that
direction is also acceptable.
TIA :)
Mvgr,
Martin
Re: Preventing external loading of xsd [message #187020 is a reply to message #186708] Thu, 25 January 2007 17:49 Go to previous messageGo to next message
Does no one have an idea about this ?
Mvgr,
Martin
Martin van den Bemt wrote:
> Hi everyone,
> TIA :)
> Mvgr,
> Martin
Re: Preventing external loading of xsd [message #187028 is a reply to message #187020] Fri, 26 January 2007 02:27 Go to previous messageGo to next message
Have you tried using the XML Catalog? See the tutorial here :
http://www.eclipse.org/webtools/community/tutorials/XMLCatal og/XMLCatalogTutorial.html
> Mvgr,
> Martin
>> Hi everyone,
appreciated.
>> TIA :)
>> Mvgr,
>> Martin
Re: Preventing external loading of xsd [message #187047 is a reply to message #187028] Fri, 26 January 2007 03:55 Go to previous messageGo to next message
Thanx for the reply craig.
The problem is that that is not an API.. I need to automatically register my xsd's so the xsd's are
loaded from my plugin. I prefer that the user doesn't have to any manual configuration for this.
Mvgr,
Martin
>> Mvgr,
>> Martin
>>> Hi everyone,
>>> editor
>>> highly
> appreciated.
>>> TIA :)
>>> Mvgr,
>>> Martin
Re: Preventing external loading of xsd [message #187122 is a reply to message #187047] Fri, 26 January 2007 12:22 Go to previous messageGo to next message
Originally posted by: valentinbaciu.hotmail.com
Martin, the XML core plug-in org.eclipse.wst.xml.core provides an API
(provisional, it's true) and an extension point mechanism that allow you to
programmatically or declaratively contribute content to the catalog. The
extension point mechanism is used - for example - by the org.wsdl4j plug-in
to contribute the WSDL schemas to the catalog. Use it as an example.I'm sure
you'll find examples of the API usage in our unit tests.
I hope this helps.
Regards, Valentin
"Martin van den Bemt" <mllist@mvdb.net> wrote in message
news:epcfl1$13o$1@utils.eclipse.org...
> Mvgr,
> Martin
>>> Mvgr,
>>> Martin
>>>> Hi everyone,
>>>> editor
>>>> highly
>> appreciated.
>>>> TIA :)
>>>> Mvgr,
>>>> Martin
Re: Preventing external loading of xsd [message #187130 is a reply to message #187122] Fri, 26 January 2007 12:29 Go to previous message
Thanx Valentin, I'll have a look at the wsdl4j plugin..
Mvgr,
Martin
> I hope this helps.
> Regards, Valentin
>> Mvgr,
>> Martin
>>>> Mvgr,
>>>> Martin
>>>>> Hi everyone,
>>>>> editor
>>>>> highly
>>> appreciated.
>>>>> TIA :)
>>>>> Mvgr,
>>>>> Martin
Previous Topic:XML Editor use in WTP 1.5.2 -
Next Topic:JSTL Warnings? WTP 1.5.2
Current Time: Mon Oct 27 21:17:26 EDT 2025
Powered by FUDForum. Page generated in 0.05199 seconds
