Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMF Client Platform] ViewModel adding children references
[EMF Client Platform] ViewModel adding children references [message #1177407] |
Sat, 09 November 2013 00:17 |
With the ViewModel I would like to consolidate controls for an elements
children in the Editor for the parent element. I see this is possible
for 0..1 and 1..1 references and have experimented with it by adding
controls for children inside of layouts and groups.
Read the 'How to customize the editor layout' article but still have
many questions about how to use some of the models elements like the
Span, GroupGrid, ShowRule, EnableRule, TableControl and How to add x..n
references?
thanks for any help,
John
Re: [EMF Client Platform] ViewModel adding children references [message #1181471 is a reply to message #1180925] |
Mon, 11 November 2013 16:21 |
Hi Jonas,
Just what I was hoping for.
thanks for all your fine work,
John
On 11/11/2013 02:46 AM, Jonas Helming wrote:
> Hi John,
> as it happens, I am currently working on a more detailed tutorial. I
> hope I will be able to publish the first version of it today. I hope it
> answers most of your questions. I will post a link as soon as it is
> published.
> Best Regards
> Jonas
> Am 09.11.2013 01:17, schrieb John E. Conlon:
>> references?
>> John
Re: [EMF Client Platform] ViewModel adding children references [message #1181519 is a reply to message #1181471] |
Mon, 11 November 2013 16:57 |
Jonas Helming Messages: 699 Registered: July 2009 |
While still writing on the tutorial, one question:
You mentioned x..n references, could you explain me a little bit more in
detail, what you want to do?
Best Regards
Jonas
Am 11.11.2013 17:21, schrieb John E. Conlon:
> Hi Jonas,
> John
>> Hi John,
>> published.
>> Best Regards
>> Jonas
>>> references?
>>> John
Re: [EMF Client Platform] ViewModel adding children references [message #1181611 is a reply to message #1181519] |
Mon, 11 November 2013 18:17 |
As an example I have an EObject named Premises that has a couple of
attributes name and id. The premises contains an EReference named
Address (1..1) that has attributes and may contain (0..1) a GeoPoint
with lat/long attributes. The Premises contains one or more people
EReferences that may contain a phone number. The Premises may also
contain one or more Program Status (0..*).
When the Premises is selected I would like the editor to show all its
children references. Now I am not clear on how that will work in the
for the child portion of the UI if there are no children. (I suspect
this is where the logic 'ShowRule' comes in?) How are multiple children
modeled in the UI with the TableControl??
Also not clear if the Editor UI on its own can create or delete children
or does one explicitly have to use the Model Explorer for creation and
deletion?
Also the question comes up regarding modeling an EObject in a ModelView
and how the Editor reacts if that modeled EObject is a child of another
EObject that is modeled and referencing the first modeled EObject. In
other words if I create a ViewModel for an EObject do I have to recreate
the same modeled portion of that child EObject if I want to see it
contained in parent?
best regards,
John
> Best Regards
> Jonas
>> Hi Jonas,
>> John
>>> Hi John,
>>> published.
>>> Best Regards
>>> Jonas
>>>> references?
>>>> John
Re: [EMF Client Platform] ViewModel adding children references [message #1182876 is a reply to message #1181611] |
Tue, 12 November 2013 13:27 |
from an ECP point of view, containment attributes are typically handled
differently depending on their multiplicity.
References with a mutliplicity of more then 1 are per default displayed
in a list of hyperlinks. Alternativly, you can specify a table control
to display the children "inline". I have documented this:
http://eclipsesource.com/blogs/tutorials/emf-forms-view-model-elements/#tablecontrol
For 0..1 references, ECP currently assumes, that the attributes of the
referenced object logically belongs to the parent. The adress is a good
example. From the user point of view, you might want to hide, that
adress is an own object. The user probably expects to enter the adress
of a premise in the same form. This can be done by placing controls on
the view of the premise, which reference attributes of the object
adress. The view model editor allows to select attributes of child
elements, too. Of course you might want to group all attributes of a
child object in the UI.
If you reference a child object in the view model, ECP will create an
empty object, if you open a premise without an adress, the adress will
be created. Does this match your requirements? Or shall the user
explicitly create a child object, e.g. a GeoPoint?
Jonas
Am 11.11.2013 19:17, schrieb John E. Conlon:
> deletion?
> best regards,
> John
>> Best Regards
>> Jonas
>>> Hi Jonas,
>>> John
>>>> Hi John,
>>>> published.
>>>> Best Regards
>>>> Jonas
>>>>> elements
>>>>> x..n
>>>>> references?
>>>>> John
Re: [EMF Client Platform] ViewModel adding children references [message #1183136 is a reply to message #1182876] |
Tue, 12 November 2013 17:05 |
Hi Jonas,
See in line comments...
thanks,
John
On 11/12/2013 07:27 AM, Jonas Helming wrote:
That's very functioal.
Do you mean hide it in the the hierarchy of the Model Explorer?
How is this done? GenModel?
Yes, I have done this and it works well.
Well the Premises must have an address, so if a Premises is created, and
the UI has been defined for the address it makes sense if the Address is
created, but an address may not have a GeoPoint, so the user should be
allowed to explicitly create or Not create it.
> Regards
> Jonas
>> deletion?
>> best regards,
>> John
>>> Best Regards
>>> Jonas
>>>> Hi Jonas,
>>>> John
>>>>> Hi John,
>>>>> published.
>>>>> Best Regards
>>>>> Jonas
>>>>>> elements
>>>>>> x..n
>>>>>> references?
>>>>>> John
Re: [EMF Client Platform] ViewModel adding children references [message #1184314 is a reply to message #1183136] |
Wed, 13 November 2013 11:11 |
comments inline...
> Hi Jonas,
> thanks,
> John
I see. We did not have this requirement before, so we would need to
develop a new control for a 0..1 reference. That means you could
consider a contribution or a sponsorship. Is one of these possibilities
an option for you?
Jonas
>> Regards
>> Jonas
>>> deletion?
>>> best regards,
>>> John
>>>> more in
>>>> Best Regards
>>>> Jonas
>>>>> Hi Jonas,
>>>>> John
>>>>>> Hi John,
>>>>>> hope it
>>>>>> published.
>>>>>> Best Regards
>>>>>> Jonas
>>>>>>> elements
>>>>>>> possible
>>>>>>> x..n
>>>>>>> references?
>>>>>>> John
Re: [EMF Client Platform] ViewModel adding children references [message #1184624 is a reply to message #1184314] |
Wed, 13 November 2013 15:30 |
Yes, I would be happy to contribute, but of course will have to dig
deeper and learn the internals first, before I could be of any help.
John
On 11/13/2013 05:11 AM, Jonas Helming wrote:
> comments inline...
>> Hi Jonas,
>> thanks,
>> John
>>> Hi,
> an option for you?
> Regards
> Jonas
>>> Regards
>>> Jonas
>>>> deletion?
>>>> best regards,
>>>> John
>>>>> more in
>>>>> Best Regards
>>>>> Jonas
>>>>>> Hi Jonas,
>>>>>> John
>>>>>>> Hi John,
>>>>>>> hope it
>>>>>>> published.
>>>>>>> Best Regards
>>>>>>> Jonas
>>>>>>>> elements
>>>>>>>> possible
>>>>>>>> x..n
>>>>>>>> references?
>>>>>>>> John
Re: [EMF Client Platform] ViewModel adding children references [message #1186364 is a reply to message #1185773] |
Thu, 14 November 2013 17:05 |
fixed in 1.1.1, please check if it works for you:
http://eclipse.org/emfclient/download.html
Am 14.11.2013 09:58, schrieb Jonas Helming:
> we were able to reproduce the first issue, there is a minor bug in the
> 1.1.0 release, we will create a hotfix for this asap:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=421709
> About the taskView.view: Where did you get this file from exactly? I
> browsed the make it happen repository and I couldn't find it.
> Thanks for the detailed report!
> Kind regards
> Jonas
> Am 12.11.2013 23:46, schrieb John E. Conlon:
>> Hi Jonas,
>> I tried to create a tableControl, but have not had any luck with my
>> model or with the 'Task' model of your example. Here is what my
>> viewModel userGroup.view looks like:
>> <org.eclipse.emf.ecp.view.model:View xmi:version="2.0"
>> xmlns:xmi="http://www.omg.org/XMI"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
>> xmlns:org.eclipse.emf.ecp.view.model="http://org/eclipse/emf/ecp/view/model"
>> xmlns:org.eclipse.emf.ecp.view.table.model="http://org/eclipse/emf/ecp/view/table/model"
>> name="UserGroup">
>> <rootEClass
>> href="http://eclipsesource.com/makeithappen/model/task#//UserGroup"/>
>> <children xsi:type="org.eclipse.emf.ecp.view.table.model:TableControl"
>> name="UserGroup" addRemoveDisabled="true">
>> <domainModelReference
>> xsi:type="org.eclipse.emf.ecp.view.table.model:TableDomainModelReference">
>> <domainModelEFeature xsi:type="ecore:EReference"
>> href="http://eclipsesource.com/makeithappen/model/task#//UserGroup/users"/>
>> </domainModelReference>
>> <columns>
>> <attribute
>> href="http://eclipsesource.com/makeithappen/model/task#//User/firstName"/>
>> </columns>
>> </children>
>> </org.eclipse.emf.ecp.view.model:View>
>> The plugin.xml of the com.eclipsesource.makeithappen.ui looks like:
>> <extension
>> point="org.eclipse.emf.ecp.view.model.provider.xmi.file">
>> <file
>> filePath="viewModel/taskView2.view">
>> </file>
>> <file
>> filePath="viewModel/userGroup.view">
>> </file>
>> </extension>
>> BTW - I am also getting parsing errors if I try to use the
>> viewModel/taskView.view viewModel from the example (right from git) so
>> I had to redefine it.
>> Any ideas what I am doing wrong?
>> thanks,
>> John
Re: [EMF Client Platform] ViewModel adding children references [message #1186555 is a reply to message #1185773] |
Thu, 14 November 2013 19:23 |
Hi Jonas,
Good to here you could reproduce this problem.
The file is in the ui plugin. Here is the link to the file:
https://raw.github.com/eclipsesource/makeithappen/master/com.eclipsesource.makeithappen.ui/viewModel/taskView.view
thanks,
John
On 11/14/2013 02:58 AM, Jonas Helming wrote:
> Kind regards
> Jonas
>> Hi Jonas,
>> name="UserGroup">
>> <rootEClass
>> <columns>
>> <attribute
>> </columns>
>> </children>
>> <extension
>> <file
>> </file>
>> <file
>> </file>
>> </extension>
>> thanks,
>> John
Re: [EMF Client Platform] ViewModel adding children references [message #1188954 is a reply to message #1186364] |
Fri, 15 November 2013 22:25 |
Hi Jonas,
1.1.1 is working for me. I was able to create table controls for
children of parent EObjects. Did notice a couple of limitations:
1. If the children have attributes that are enumerations the
TableControl column only shows a text type control vs a drop down menu.
Is this a current limitation or can I configure something to get a drop
down with all the enumerations? Of course for now I can just use the
model explorer to configure these values.
2. A child displayed in the TableControl may also be a parent of
optional objects, Will the table control eventually be able to handle
children of its own in columns?
What may be a simple solution for these more complicated types inside a
tableControl is to allow the tableView modeler to display links to these
objects, which would then visualize in their own editor showing either a
customized view or a default one.
thanks again for all your work,
John
>> Kind regards
>> Jonas
>>> Hi Jonas,
>>> name="UserGroup">
>>> <rootEClass
>>> <columns>
>>> <attribute
>>> </columns>
>>> </children>
>>> <extension
>>> <file
>>> </file>
>>> <file
>>> </file>
>>> </extension>
>>> thanks,
>>> John
Re: [EMF Client Platform] ViewModel adding children references [message #1194916 is a reply to message #1188954] |
Mon, 18 November 2013 19:19 |
Hi John,
sorry for the late answer, I have overseen this second post, the thread
is pretty long right now :-)
comments inline...
Am 15.11.2013 23:25, schrieb John E. Conlon:
> Hi Jonas,
There is currently no drop down, could you please file a feature request
in Bugzilla?
The question is how this should look like. Would you espect to unfold
the entry then? If so, we would probably need to use a more powerful
table, e.g. NATtable
You should be able to double click an element in the table to open it up
in a new editor. Is this what you meant?
Best Regards
Jonas
> John
>>> Hi,
>>> Kind regards
>>> Jonas
>>>> Hi Jonas,
>>>> name="UserGroup">
>>>> <rootEClass
>>>> <children
>>>> <columns>
>>>> <attribute
>>>> </columns>
>>>> </children>
>>>> <extension
>>>> <file
>>>> </file>
>>>> <file
>>>> </file>
>>>> </extension>
>>>> thanks,
>>>> John
Re: [EMF Client Platform] ViewModel adding children references [message #1210105 is a reply to message #1194916] |
Mon, 25 November 2013 21:33 |
Hi Jonas,
Now I am sorry for the late response... see in line:
> in Bugzilla?
Filed https://bugs.eclipse.org/bugs/show_bug.cgi?id=422522
I think that this might be overkill here and the approach is to do just
show a link as I mention below...
Yes, just a link. I see these are used in the default editor.
best regards,
John
Re: [EMF Client Platform] ViewModel adding children references [message #1211839 is a reply to message #1210105] |
Tue, 26 November 2013 16:46 |
Did you check, whether the double click already works for you?
Am 25.11.2013 22:33, schrieb John E. Conlon:
> Hi Jonas,
>> in Bugzilla?
> best regards,
> John
Current Time: Fri Apr 26 10:26:53 GMT 2024
Powered by FUDForum. Page generated in 0.04410 seconds
