Hi!
I am trying to extend the EMF compare to implement my own algorithm to compare 2 models.
I developed this
package org.eclipse.emf.compare.impl;
import java.io.File;
import java.net.URI;
import org.eclipse.emf.compare.Comparison;
import org.eclipse.emf.compare.EMFCompare;
import org.eclipse.emf.compare.match.DefaultComparisonFactory;
import org.eclipse.emf.compare.match.DefaultEqualityHelperFactory;
import org.eclipse.emf.compare.match.DefaultMatchEngine;
import org.eclipse.emf.compare.match.IComparisonFactory;
import org.eclipse.emf.compare.match.IMatchEngine;
import org.eclipse.emf.compare.match.eobject.IEObjectMatcher;
import org.eclipse.emf.compare.match.impl.MatchEngineFactoryImpl;
import org.eclipse.emf.compare.match.impl.MatchEngineFactoryRegistryImpl;
import org.eclipse.emf.compare.scope.IComparisonScope;
import org.eclipse.emf.compare.utils.UseIdentifiers;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl;
* @since 3.1
public class Mcompare {
public Comparison compare(File model1, File model2) {
// Load the two input models
ResourceSet resourceSet1 = new ResourceSetImpl();
ResourceSet resourceSet2 = new ResourceSetImpl();
String xmi1 = "path/to/first/model.xmi";
String xmi2 = "path/to/second/model.xmi";
load(xmi1, resourceSet1);
load(xmi2, resourceSet2);
// Configure EMF Compare
IEObjectMatcher matcher = DefaultMatchEngine.createDefaultEObjectMatcher(UseIdentifiers.NEVER);
IComparisonFactory comparisonFactory = new DefaultComparisonFactory(
new DefaultEqualityHelperFactory());
IMatchEngine.Factory matchEngineFactory = new MatchEngineFactoryImpl(matcher, comparisonFactory);
matchEngineFactory.setRanking(20);
IMatchEngine.Factory.Registry matchEngineRegistry = new MatchEngineFactoryRegistryImpl();
matchEngineRegistry.add(matchEngineFactory);
EMFCompare comparator = EMFCompare.builder().setMatchEngineFactoryRegistry(matchEngineRegistry)
.build();
// Compare the two models
IComparisonScope scope = EMFCompare.createDefaultScope(resourceSet1, resourceSet2);
return comparator.compare(scope);
private void load(String absolutePath, ResourceSet resourceSet) {
URI uri = URI.createFileURI(absolutePath);
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi",
new XMIResourceFactoryImpl());
// Resource will be loaded within the resource set
resourceSet.getResource(uri, true);
// for standalone usage
IMatchEngine.Factory.Registry registry = MatchEngineFactoryRegistryImpl.createStandaloneInstance();
// for OSGi (IDE, RCP) usage
// IMatchEngine.Factory.Registry registry = EMFCompareRCPPlugin.getMatchEngineFactoryRegistry();
final IMatchEngine customMatchEngine = new comparador();
IMatchEngine.Factory engineFactory = new MatchEngineFactoryImpl() {
public IMatchEngine getMatchEngine() {
return customMatchEngine;
engineFactory.setRanking(20); // default engine ranking is 10, must be higher to override.
registry.add(engineFactory);
EMFCompare.builder().setMatchEngineFactoryRegistry(registry).build().compare(scope);
But I can not achieve successful in coding it.
How do I implement my algorithm? Where am I going wrong and how do I fix the error?
I am using Eclipse Kepler.
Thank you very much!
