| Property view page [message #185808] |
Thu, 30 June 2005 03:27  |
Originally posted by: rabius.yahoo.de
Hello!
I implement a multipage GEF/EMF editor. One page displays some source code
whereas the other page displays the graphical components. If I click on a
graphical component its corresponding property page is shown in the
properties view. Now when I switch back to the source code page I would
like to clear to properties page. How can I achieve this? How does the
mechanism work?
TIA, Mario
| Re: Property view page [message #185815 is a reply to message #185808] |
Thu, 30 June 2005 03:49  |
Originally posted by: mvsteenbergen.eljakim.scratch-this.nl
Maybe you could clear the selection? Apparently the selection is
preserved, because the properties are still visible. And when you switch
back to the graphical editor tab, the part is still selected.
However, I have no idea how to clear the selection. It seems Eclipse
uses some sort of Eclipse-wide selection, because if I select an
IPropertySource in my Outline View, the Properties View detects this. Is
there any documentation about how this seemingly Eclipse-wide selection
works? Eventually I want to synchronize the outline tree and the
graphical editor's selection. How do I do this?
Apologies for mixing my question with Mario's. I'm not sure if I should
have started a new thread, but I thought it appropriate I reply here
because the question seems to be related.
Good luck, Mario. Repliers, thanks in advance.
Martijn van Steenbergen.
> would like to clear to properties page. How can I achieve this?
FUDForum. Page generated in 0.03195 seconds
