Java 6.0 [message #185717] |
Tue, 26 December 2006 20:22  |
Originally posted by: william.rouse.ws
Now that java 6.0 is released, are there any adjustments or additions that
need to be made to Eclipse?
WBR
Re: Java 6.0 annotation processing [message #185985 is a reply to message #185824] |
Thu, 28 December 2006 19:26   |
Originally posted by: wharley.bea.com
"William Bradley Rouse" <william@rouse.ws> wrote in message
news:cae73f4aa3faa78f36f881e4df424bf9$1@www.eclipse.org...
> Wayne:
> Thanks! I got it to work with just a little sputter.
> Walter:
> What is "Java 6 (JSR-269) annotation processors"?
In Java 5, Sun introduced the concept of "annotation processing" - a way for
third-party code to run at compile time and be able to inspect annotations
on the source code and generate additional Java classes that would then get
compiled along with the original source code. Among other things, it's a
way of formalizing things like EJB generation that had been done with tools
based on javadoc. There are many advantages, such as type-safety (to
javadock, everything is a string).
However, in Java 5, the interface that these "annotation processors" had to
talk to was a Sun proprietary interface, com.sun.mirror.apt.*. In Java 6,
the interface has been standardized (it's in javax.annotation.processing and
javax.lang.model), .
Eclipse 3.2 supported Sun-style Java 5 annotation processors: that is, it is
possible to write annotation processors and it is possible to add them to
the Java build. Eclipse 3.3 will support the new Java 6 standard, along
with the old non-standard interface.
You can read a bit more about them, if you choose to, at
http://www.eclipse.org/jdt/apt/introToAPT.html. Note that still does not
mention Java 6.
FUDForum. Page generated in 0.09745 seconds
