| Problem insert elements on a diagram Eclipse RCP [message #185398] |
Mon, 05 May 2008 10:10  |
Originally posted by: nicolas.freiss.gmail.com
Hello
I am working on the GMF technology and I am trying to generate a plugin
based on an ecore model (mindmap). So, I followed the tutorial
(http://wiki.eclipse.org/GMF_Tutorial) and all is OK when I generate a RCP
application. When I lauch this application, I can insert elements on a
diagram and everything works correctly.
Unfortunately, when I try without RCP, the plugin is correctly generated
(based on the same gmfmap) but I can't insert elements on the diagram.
There is just a cross when I try to insert an element in the diagram.
I tried with or without the GMF Dashboard but it doesn't change. These
plugins are based on the same eclipse project. There is just differences
in the mindmap.gmfgen (based on the same gmfmap) and the package
org.eclipse.gmf.monTroisiemePlugin.mindmap.diagram (generated with the
mindmap.gmfgen)
Thanks for your help
Nicolas
| Re: Problem insert elements on a diagram Eclipse RCP [message #185443 is a reply to message #185398] |
Mon, 05 May 2008 12:02  |
Originally posted by: 5d5.mail.ru
Could you try TaiPan RCP example? I'm able to create, edit, save and
load these diagrams.
Nicolas wrote:
> Hello
> RCP application. When I lauch this application, I can insert elements on
> a diagram and everything works correctly.
> mindmap.gmfgen)
> Regards
> Nicolas
FUDForum. Page generated in 0.03509 seconds
