Home » Language IDEs » Java Development Tools (JDT) » ANT Eclipse get -data Workspace
ANT Eclipse get -data Workspace [message #1174603] Thu, 07 November 2013 02:44 Go to next message
I search a example on a build.xml file ant to get Workspace Eclipse launch.
Thank for the response ....
Chris
Re: ANT Eclipse get -data Workspace [message #1179776 is a reply to message #1174603] Sun, 10 November 2013 09:39 Go to previous messageGo to next message
I'm not sure I understand your question. You want to lauch Eclipse via ant? Why would you want that?
Or what exactly should the build.xml do?
Stephan
Re: ANT Eclipse get -data Workspace [message #1188111 is a reply to message #1179776] Fri, 15 November 2013 07:56 Go to previous message
No problem to launch Eclipse.
I would get the "properties Eclipse data workspace" with a script ant.
Example with a build ant file :
<target name="copyJbossWeb" description="">
<copyfile src="${jboss}/workspace_config/jboss-web.xml" dest="${eclipseDataWorkspace???}/jmanager/src/main/webapp/WEB-INF/jboss-web.xml" forceoverwrite="true" />
</target>
The ${eclipseDataWorkspace???} is incorrecte. I don't know the value.
Previous Topic:Unable to install JBoss AS server adapter
Next Topic:Writing JAR from plug-in (not from File menu)
Current Time: Sun May 18 10:37:56 EDT 2025
Powered by FUDForum. Page generated in 0.03390 seconds
