Re: Release candidate 0.9.0 at Q4E [message #18681 is a reply to message #18658] |
Wed, 29 April 2009 17:20 |
Abel Mui Messages: 247 Registered: July 2009 |
Hello Marek,
Thanks for your report... see below for some comments.
Marek Romanowski wrote:
> 3. After a few out of memory errors something strange occured:
> - I could open file (.java for example)
> - I could edit it (adding some text)
> - I couldn't(!) save it, because save operation was blocked until some
> other operation finish.
> In Progres view I saw only sleeping "Synchronizing task list" and my save
> operation. Restarts (some with -clean option) did not help - situation was
> the same. I had do uninstall IAM and that helped.
> Sorry for lack of details, I don't know how to give you more description.
> If you have some questions, possible solution or could describe where to
> find any logs from IAM work i would try to reproduce situation and post
> results.
IAM writes to the eclipse log, so that's the first place where you could
look for possible errors.
If you are able to test again, please:
- open the Events view, so you can see any messages by maven. Remember to
change the filter to "debug" level so you can see all output
- I have to verify this, but it is possible that the first maven run
after importing a project is locking the project and not showing on the
progress view. With 50+ projects, it might take some time for maven to
run, specially in online mode (the default).
Regaring the out of memory exceptions, maybe you could workaround them by
importing progects in smaller groups?
Abel Muiño
Re: Release candidate 0.9.0 at Q4E [message #568786 is a reply to message #18658] |
Hello Marek,
> results.
Abel Muiño
FUDForum. Page generated in 0.04880 seconds
