Re: focus on active task button is missing in Package Explorer [message #18927 is a reply to message #17474] |
Wed, 25 July 2007 05:44 |
Originally posted by: beatmik.acm.org
Easiest thing to do is to install all of the latest Mylyn features from:
http://www.eclipse.org/mylyn/downloads/
If that still doesn't work, make sure you are using Java 5 or later and
read through te following:
http://wiki.eclipse.org/index.php/Mylyn_FAQ#Installation_Tro ubleshooting
If the install still doesn't work please file a bug report so that we
can diagnose further, and make sure to include any entries mentioning
Mylyn in Window -> Show View -> PDE Runtime -> Error Log.
Mik
Pazargic Antonel Ernest wrote:
> After I installed Eclipse 3.3 final (Europa) and Mylyn 2.0 (final) and strange situation occurred. In Package Explorer view the active task button is missing. I also have the same Eclipse and Mylyn versions installed on my working computer and there is not such problem at all. I've tried to solve the problem but without success.
> It's a incorrect settings problem, a installation problem, a plugins conflict problem or is simply a bug. Please let me know because mylyn is the most useful plugin for me. And the new Xplanner connector extends its power.
> Thanks a lot, jtonic.
> P.S. Uninstall the mylyn, remove the .mylyn folder and reinstall it didn't solve the problem.
Re: focus on active task button is missing in Package Explorer [message #18971 is a reply to message #17474] |
Wed, 25 July 2007 07:22 |
I think I saw a similar problem, but I can't remember if it was with
Mylar 1.0 or with Mylyn 2.0.
If I remember well, in my case, simply deactivating and re-activating
the task did the job. Also try to check and uncheck the "Toggle focused
mode on navigator views when task is activated" in Mylyn context
preferences: the problem in my case might have arisen when that option
was unchecked...
Hope to have been of any help.
Mauro.
FUDForum. Page generated in 0.03527 seconds
