[TCL] Command Completion [message #1173309] |
Wed, 06 November 2013 07:31  |
when I do code completion to complete a Tcl command line that calls a
procedure the editor completes the command line with parentheses around
and commas between the arguments such as I were writing C code.
Example:
xwsdl::foreachBinding(var,parent,code)
I would expect
xwsdl::foreachBinding $var $parent $code
or just
without the arguments.
I found nothing in the web regarding this behavior?
Is this a known issue?
Is there something I can do (seting some kind of preferences) to correct
the behavior?
If I wanted to fix the code of the Tcl extension, where would I have to
start?
Thanks and Regards,
Dirk
FUDForum. Page generated in 0.03700 seconds
