Home » Modeling » GMF (Graphical Modeling Framework) » SVG problem
SVG problem [message #184329] Fri, 25 April 2008 08:05 Go to next message
Using SVG figures in my diagram goes well but when I try to
use a SVG figure that has a xlink to an image (gif) or
an embbeded Base64 image I see a red cross or a default image
instead of the linked one. ¿Can I use this SVG feature or it
is not supported in GMF?
Thanks in advance.
Salva.
Re: SVG problem [message #184579 is a reply to message #184329] Mon, 28 April 2008 11:56 Go to previous messageGo to next message
Hi Salva,
This may be an issue in the Batik libraries used by the GMF Runtime. Can you
raise a bugzilla and attach sample image files?
Cheers...
Anthony
"Salva "Mart
Re: SVG problem [message #184657 is a reply to message #184579] Tue, 29 April 2008 05:51 Go to previous message
Hi Anthony,
Done!
I've already raised the bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=229256
Best regards!
Previous Topic:Change Document Root and Refresh
Next Topic:Displaying Model Elements of "foreign" models
Current Time: Wed Nov 05 05:25:28 EST 2025
Powered by FUDForum. Page generated in 0.03656 seconds
