Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Texo] Save proxy
Re: [Texo] Save proxy [message #1170213 is a reply to message #1170177] |
Mon, 04 November 2013 13:32 |
Hi Bastian,
Hmm what goes wrong on the server, is a new Room object maybe created on the server?
gr. Martin
On 11/04/2013 02:05 PM, Bastian Wagenfeld wrote:
> Hi Martin,
> I've got a problem regarding the proxy resolving. My model looks like this.
> - House
> - Room
> - Door
> Now I load a house from my database with one child level. So the house is resolved, but its child Room is an eProxy
> (which is what I want). If I change the Houses name and save the resource (resource.save(new HashMap<>()), the Room
> doesn't contain the Door anymore.
> Is there a standard method to prevent Texo from saving Proxy objects, because this will set the object's fields to null?
> Best regards
> Bastian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] Save proxy [message #1176400 is a reply to message #1174823] |
Fri, 08 November 2013 10:02 |
Hi Bastian,
Okay, to get some better idea, so when loading these proxies are they resolved against already loaded objects, but the
only thing is that the proxy is not unset? or
is the proxy not resolved against already loaded objects?
gr. Martin
On 11/07/2013 11:35 AM, Bastian Wagenfeld wrote:
> Ok, this might be a little hard to understand, so here are some additions:
> The object I reload via the query references (not contains) objects that have already been loaded at system start. The
> EMF-object I want to reload already references the whole object which was already resolved at the system start. But the
> proxy URI of the reference is set anyway.
> I hope this is understandable at all...
> Bastian
The Netherlands
Re: [Texo] Save proxy [message #1185756 is a reply to message #1184039] |
Thu, 14 November 2013 08:44 |
No Problem Bastian! I have been looking at it further. Could the following be happening:
- large objects are loaded at startup
- other objects are loaded at click, their json contains proxy-references to the other large objects
- the reference to the other objects is correctly resolved but as the json contains a proxy uri, the proxy uri is set in
the large-already-loaded object
So before the click-load the proxy uri of the large-already-loaded object is not set, after the click-load the large
objects have their proxy uri set.
Can you check/debug if you see this (or something else)?
(at least looking at the code this could happen)
gr. Martin
On 11/13/2013 08:19 AM, Bastian Wagenfeld wrote:
> Hi Martin,
> sorry for that late answer. You are right, the proxies are not resolved against already loaded objects. Most of the
> objects are retrieved during startup, but some of the objects are to large to fetch them as well. So they are reloaded
> by click. This object references other objects that have already been loaded. In debug-mode for example, I can see that
> they are set correctly, but there proxy URIs aren't unset. I solved this by setting all URIs null. So no proxies are
> resolved. This is ok, because there is only one place where this happens, till now.
> Best regards Bastian
The Netherlands
Re: [Texo] Save proxy [message #1191024 is a reply to message #1187578] |
Sat, 16 November 2013 22:44 |
Hi Bastian,
I published a new build which should solve this, can you try it?
gr. Martin
On 11/15/2013 08:07 AM, Bastian Wagenfeld wrote:
> Hi Martin,
> yes, that's right. The objects loaded at startup aren't very large, but rather small. The objects loaded by click are
> the large objects, but the process itself is like you described it. An object loaded at startup is completely resolved
> and has no uri set. It has no reference on the lazily loaded object but the other way round the click-loaded has a
> reference on it. So the object gets loaded by a query. Afterwards the lazy object has no uri set, but the startup-object
> gets an uri.
> Best regards and thank you!
> Bastian
The Netherlands
Current Time: Fri Apr 26 14:41:34 GMT 2024
Powered by FUDForum. Page generated in 0.03979 seconds
