Home » Modeling » GMF (Graphical Modeling Framework) » creating a diagram
creating a diagram [message #183783] Tue, 22 April 2008 03:38 Go to next message
Originally posted by: aritz.galdos.iese.fraunhofer.de
Good morning everybody!!!
I have created an editor, where I can draw some rectangles and then I can
create connection between them. This all staff is working, I mean, I create
a diagram, then the user makes the diagram and at the end he saves and
everything is ok. So, creating an empty diagram is working.
No, I want to create a diagram automatically with some rectangles and some
connections since the beginning. I mean, when the user wants to create a
diagram everything should work like the situation explained in the first
paragraph but instead of creating an empty diagram, some rectangles should
appear.
So, how can I add components to the diagram file automatically? If I am not
wrong first I create the domain model, then I add components to it and at
the end I create the diagram model. Don't I? Which is the methods that I
should use to add the components to the domain model? And to create the
diagram model?
Thank you in advance and sorry because of my poor English
Aritz
Re: creating a diagram [message #183814 is a reply to message #183783] Tue, 22 April 2008 06:42 Go to previous messageGo to next message
Hello Aritz,
> am not wrong first I create the domain model, then I add components to
> it and at the end I create the diagram model. Don't I? Which is the
You are right!
> methods that I should use to add the components to the domain model?
> And to create the diagram model?
See generated ???DiagramEditorUtil.createDiagram() as an example.
Alex Shatalin
Re: creating a diagram [message #183848 is a reply to message #183814] Tue, 22 April 2008 08:51 Go to previous messageGo to next message
HI!!
Thank you!!! But I have done this and it is working. I have created the
modeldiagram file, but now I want to add some nodes and relations that I
have stored in an object. How can I "update" this file?
Thank you very much!!!
Aritz
"Alex Shatalin" <vano@borland.com> wrote in message
news:3c3172e6215be8ca728d85b4ea20@news.eclipse.org...
> Hello Aritz,
> You are right!
> Alex Shatalin
Re: creating a diagram [message #183865 is a reply to message #183848] Tue, 22 April 2008 08:54 Go to previous messageGo to next message
Hello Aritz,
If you nedd to update model file on each openning then try implementing/modifying
generated ???CanonicalEditPolicy for the diagram.
Alex Shatalin
Re: creating a diagram [message #183880 is a reply to message #183865] Tue, 22 April 2008 10:09 Go to previous messageGo to next message
Hello again!!
Thank you for answering but I still have problems. I don't know if I don't
understand you or you don't understand me, so I will try to explain my
situation better. So, let's start!
I have an object where all my nodes and relation between them are saved in
it. First, I have the nodes, and under them I have the relations. In the
other side, I have created all the files that I need by
RuntimeViewmodelDiagramEditorUtil.createDiagram(...). So, until now, I have
the object with all the information and all the file that I need, which is
called example.xxx, where xxx is my EMF model name.
When I create the file, the file contains the next code:
< de.fhg.iese.pulse.SAVE.core.runtimemodel.viewmodel:RTDiagram
xmi:version="2.0"
xmlns:de.....viewmodel="http:///.../RuntimeViewmodel.ecore"/>
And I Would like to have apart from that, something like the next code:
<node name...
<relation name... />
</node>
It means that now, I want to save all the nodes and all the relations in the
file hierarquically. And that is my problem. I don't know how to add the
second part to the first part.
I hope that now the question is explained better. If the answer is still
the before one, I am sorry but could you explain me better?
Thank you very much, really!!
Aritz
P.D: I am sorry because of my poor English
news:3c3172e6215e98ca729fefd888ef@news.eclipse.org...
> Hello Aritz,
> implementing/modifying generated ???CanonicalEditPolicy for the diagram.
> Alex Shatalin
Re: creating a diagram [message #184045 is a reply to message #183880] Wed, 23 April 2008 08:57 Go to previous messageGo to next message
Hello!!!
I wrote yesterday asking some doubts and I get to solve one part but no all
of them. I think that this should be the seudo code. If I am wrong, correct
me, please:
EObject object;
Resource r = ...DiagramEditorUtil.createDiagram(...);
final Resource modelResource = r.getResourceSet().getResource(..., true);
final Resource diagramResource = r.getResourceSet().getResource(..., true);
modelResource.getContents().add(object);
Diagram dia =
ViewService.createDiagram(object,RTDiagramEditPart.MODEL_ID, RuntimeViewmodelDiagramEditorPlugin.DIAGRAM_PREFERENCES_HINT );
if (dia != null) {
diagramResource.getContents().add(dia);
dia.setName(...);
dia.setElement(object);
try {
modelResource.save(RuntimeViewmodel.diagram.part.RuntimeView modelDiagramEditorUtil.getSaveOptions());
} catch (IOException e) {
RuntimeViewmodel.diagram.part.RuntimeViewmodelDiagramEditorP lugin.getInstance().logError(
"Unable to store model and diagram resources", e); //$NON-NLS-1$
But I have a problem. It returns me a Illegal State Exception, meaning that
no transaction is currently active. Can anybody help me? Please??? Thank you
in advance and I am sorry becuase of my poor English!!!
Aritz
"Aritz" <aritz.galdos@iese.fraunhofer.de> wrote in message
news:fukril$p6c$1@build.eclipse.org...
> Hello again!!
> have the object with all the information and all the file that I need,
> which is called example.xxx, where xxx is my EMF model name.
> xmi:version="2.0"
> xmlns:xmi="http://www.omg.org/XMI"
> <node name...
> </node>
> the file hierarquically. And that is my problem. I don't know how to add
> the second part to the first part.
> Aritz
>> Hello Aritz,
>> Alex Shatalin
Re: creating a diagram [message #184102 is a reply to message #184045] Thu, 24 April 2008 03:42 Go to previous messageGo to next message
Hello!!
Can anybody help me? Do you understand my problem? Does anybody know how to
create the diagrams by code? If somebody can help me it is greateful!! Thank
you in advance!!!
Aritz
news:funbo7$skc$1@build.eclipse.org...
> Hello!!!
> all of them. I think that this should be the seudo code. If I am wrong,
> correct me, please:
> EObject object;
> true);
> Diagram dia =
> if (dia != null) {
> dia.setName(...);
> try {
> that no transaction is currently active. Can anybody help me? Please???
> Thank you in advance and I am sorry becuase of my poor English!!!
> Aritz
>> Hello again!!
>> don't understand you or you don't understand me, so I will try to explain
>> my situation better. So, let's start!
>> in it. First, I have the nodes, and under them I have the relations. In
>> the other side, I have created all the files that I need by
>> <?xml version="1.0" encoding="UTF-8"?>
>> xmi:version="2.0"
>> <node name...
>> </node>
>> Aritz
>>> Hello Aritz,
>>> Alex Shatalin
Re: creating a diagram [message #184130 is a reply to message #184045] Thu, 24 April 2008 06:10 Go to previous messageGo to next message
Hello!!!
I am debuging and debuging the code and I have seen that the "error" is when
I execute the next sentence: modelResource.getContents().add(object);
In TransactionChangeRecorder.class the method assertWriting (),
gettingTheActiveTransaction is null. I mean, the activeTransaction is null.
Does anybody know why? Any idea?
Aritz
> Hello!!!
> correct me, please:
> EObject object;
> true);
> Diagram dia =
> if (dia != null) {
> dia.setName(...);
> try {
> Aritz
>> Hello again!!
>> xmi:version="2.0"
>> <node name...
>> </node>
>> Aritz
>>> Hello Aritz,
>>> Alex Shatalin
Re: creating a diagram [message #184144 is a reply to message #184130] Thu, 24 April 2008 08:09 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
Model should be modified within a write transaction; see
AbstractTransactionalCommand
Aritz wrote:
> Hello!!!
> Aritz
>> Hello!!!
>> correct me, please:
>> EObject object;
>> true);
>> Diagram dia =
>> if (dia != null) {
>> dia.setName(...);
>> try {
>> Aritz
>>> Hello again!!
>>> xmi:version="2.0"
>>> <node name...
>>> </node>
>>> Aritz
>>>> Hello Aritz,
>>>> Alex Shatalin
Re: creating a diagram [message #184152 is a reply to message #184144] Thu, 24 April 2008 09:00 Go to previous messageGo to next message
Hi!!
Thank you for answering me!!! I have seen AbstractTransactionalCommand and I
have tried some different things with it. The code which I added in a post
before, is based in AbstractTransactionaCommand. I createDiagram first of
all and I get back a Resource. From here, I get back the modelResource and
the diagramResource. And now, I want to add my model to the modelResource
and here is the problem.
I have tried also using next piece of code that is generated in the
....DiagramEditorUtil but get the same problem.
AbstractTransactionalCommand command = new AbstractTransactionalCommand(
editingDomain,
"Creating diagram and model", Collections.EMPTY_LIST) { //$NON-NLS-1$
protected CommandResult doExecuteWithResult ....
Has anybody another idea for the solution of this problem?
Thank youo in advance and I am sorry because of my poor English!!
Aritz
"Dmitry Stadnik" <5d5@mail.ru> wrote in message
news:fupt9c$oij$2@build.eclipse.org...
> Aritz wrote:
>> Hello!!!
>> when I execute the next sentence:
>> null. Does anybody know why? Any idea?
>> Aritz
>>> Hello!!!
>>> correct me, please:
>>> EObject object;
>>> true);
>>> true);
>>> Diagram dia =
>>> if (dia != null) {
>>> dia.setName(...);
>>> try {
>>> Aritz
>>>> Hello again!!
>>>> explain my situation better. So, let's start!
>>>> xmi:version="2.0"
>>>> <node name...
>>>> </node>
>>>> in the file hierarquically. And that is my problem. I don't know how to
>>>> add the second part to the first part.
>>>> still the before one, I am sorry but could you explain me better?
>>>> Aritz
>>>>> Hello Aritz,
>>>>> diagram.
>>>>> Alex Shatalin
Re: creating a diagram [message #184154 is a reply to message #184152] Thu, 24 April 2008 10:29 Go to previous messageGo to next message
Hi everybody!!!
I have just gotten to create the file of the model perfectly but I still
can't add the "diagram" to the diagram I mean, I create both files, and I
add refresh the model file, but I can't refresh the diagramFile. I use the
same methods, but it does not work. The diagramResource is ok, I have
checked. Any idea?
Thank you!!!
Aritz
news:fuq08u$c7p$1@build.eclipse.org...
> Hi!!
> I have tried some different things with it. The code which I added in a
> post before, is based in AbstractTransactionaCommand. I createDiagram
> first of all and I get back a Resource. From here, I get back the
> modelResource and the diagramResource. And now, I want to add my model to
> the modelResource and here is the problem.
> editingDomain,
> Aritz
>> Aritz wrote:
>>> Hello!!!
>>> Aritz
>>>> Hello!!!
>>>> correct me, please:
>>>> EObject object;
>>>> true);
>>>> true);
>>>> Diagram dia =
>>>> if (dia != null) {
>>>> dia.setName(...);
>>>> try {
>>>> Aritz
>>>>> Hello again!!
>>>>> saved in it. First, I have the nodes, and under them I have the
>>>>> relations. In the other side, I have created all the files that I need
>>>>> by RuntimeViewmodelDiagramEditorUtil.createDiagram(...). So, until
>>>>> now, I have the object with all the information and all the file that
>>>>> I need, which is called example.xxx, where xxx is my EMF model name.
>>>>> xmi:version="2.0"
>>>>> code:
>>>>> <node name...
>>>>> </node>
>>>>> to add the second part to the first part.
>>>>> Aritz
>>>>>> Hello Aritz,
>>>>>> diagram.
>>>>>> Alex Shatalin
Re: creating a diagram [message #184294 is a reply to message #184154] Fri, 25 April 2008 05:42 Go to previous messageGo to next message
Hi!!
Can anybody help me, please? I don't know what more I can try to make it
work. The part of the code where I save the diagrams is the same as the
....DiagramEditorUtil, exactly this one:
this one works but when I want to save the diagram part, it doens't work:
diagramResource.save(RuntimeViewmodel.diagram.part.RuntimeVi ewmodelDiagramEditorUtil.getSaveOptions());
The program goes on but it is not saved the information of the diagram. Any
idea? Please!! Thank you!!!
Aritz
news:fuq5h4$tur$1@build.eclipse.org...
> Hi everybody!!!
> checked. Any idea?
> Thank you!!!
> Aritz
>> Hi!!
>> and I have tried some different things with it. The code which I added in
>> a post before, is based in AbstractTransactionaCommand. I createDiagram
>> editingDomain,
>> Aritz
>>> Aritz wrote:
>>>> Hello!!!
>>>> Aritz
>>>>> Hello!!!
>>>>> no all of them. I think that this should be the seudo code. If I am
>>>>> wrong, correct me, please:
>>>>> EObject object;
>>>>> true);
>>>>> true);
>>>>> Diagram dia =
>>>>> if (dia != null) {
>>>>> dia.setName(...);
>>>>> try {
>>>>> Please??? Thank you in advance and I am sorry becuase of my poor
>>>>> English!!!
>>>>> Aritz
>>>>>> Hello again!!
>>>>>> need by RuntimeViewmodelDiagramEditorUtil.createDiagram(...). So,
>>>>>> until now, I have the object with all the information and all the
>>>>>> file that I need, which is called example.xxx, where xxx is my EMF
>>>>>> model name.
>>>>>> xmi:version="2.0"
>>>>>> code:
>>>>>> <node name...
>>>>>> </node>
>>>>>> Aritz
>>>>>>> Hello Aritz,
>>>>>>> diagram.
>>>>>>> Alex Shatalin
Re: creating a diagram [message #184470 is a reply to message #184154] Mon, 28 April 2008 02:46 Go to previous message
Hello!!
During last week, I wrote some messages but I didn't get the good answer for
my problem. I still have this problem and I don`t knowhow to go on. Can
anybody help me, please? I don`t know wha more I can try to solve this
problem!
Thank you very much in advance, and I am sorry because of my poor English!!
Aritz
> Hi everybody!!!
> checked. Any idea?
> Thank you!!!
> Aritz
>> Hi!!
>> editingDomain,
>> Aritz
>>> Aritz wrote:
>>>> Hello!!!
>>>> Aritz
>>>>> Hello!!!
>>>>> EObject object;
>>>>> true);
>>>>> true);
>>>>> Diagram dia =
>>>>> if (dia != null) {
>>>>> dia.setName(...);
>>>>> try {
>>>>> English!!!
>>>>> Aritz
>>>>>> Hello again!!
>>>>>> model name.
>>>>>> xmi:version="2.0"
>>>>>> code:
>>>>>> <node name...
>>>>>> </node>
>>>>>> Aritz
>>>>>>> Hello Aritz,
>>>>>>> diagram.
>>>>>>> Alex Shatalin
Previous Topic:Need help: non-visible element issue?
Next Topic:info about new
Current Time: Wed Nov 05 05:25:31 EST 2025
Powered by FUDForum. Page generated in 0.05042 seconds
