Home » Language IDEs » Java Development Tools (JDT) » Java help from within Eclipse?
| Java help from within Eclipse? [message #183510] |
Mon, 25 October 2004 10:54  |
Sorry for this newbie question, but I can't find the answer in my Eclipse
book.
I'm tyring to go from good old JBuilder to Eclipse. One of the things I
really like about JBuilder is the ability to get help on Java just by
going to Help and selecting Java Reference.
For example, in JBuilder I can go to Help, Java Reference, then click on
Index and type in a keyword.
Is there any way to, within Eclipse, get this same functionality?
What I would like to be able to do is add this help based on the version
of Java that I am running (1.5 or 1.4 for example).
Thanks!
| Re: Java help from within Eclipse? [message #183539 is a reply to message #183531] |
Mon, 25 October 2004 12:21   |
Yes, I know about the f2 key, but how can you configure Eclipse to access
the java documentation? I think this may help bridge the gap from what I
have in JBuilder.
Jose Vilmar Estacio de Souza wrote:
> I'm not sure if this is exactly what you're looking for.
> Placing the cursor over an object and pressing the f2 key, brings a dialog
> with documentation about this object. This happens if you've the sources
> installed.
> Also you can configure eclipse to access the java documentation.
> "Darrin" <darrin_p_s@att.net> wrote in message
> news:clj42r$f8a$1@eclipse.org...
> > book.
> > Thanks!
| Re: Java help from within Eclipse? [message #183563 is a reply to message #183539] |
Mon, 25 October 2004 14:53   |
If I'm not mistaken, when adding a new .jar to your project you have an
option to specify an URL in which the documentation is present. Since this
is done, you can press shift+f2 when the cursor is over an object name and
eclipse will show this documentation by invoking a browser. I suspect that
eclipse knows automagically where is the documentation to JDK. If this is
correct, you can simply press shift+f2 to access it.
news:clj96s$r8f$1@eclipse.org...
> have in JBuilder.
> Thanks
>> dialog
>> installed.
>> > Eclipse
>> > book.
>> > I
>> > on
>> > version
>> > Thanks!
| Re: Java help from within Eclipse? [message #183569 is a reply to message #183563] |
Mon, 25 October 2004 15:08  |
Yes, that works just fine, and thanks for pointing it out.
What I was hoping for would be a search facility like the one for
Eclipse's internals, but instead for Java's like in the example I gave
below where you select Index and then type in the word you are looking for.
I guess Eclipse doesn't have this sort of thing yet. Great tool though
none the less.
> > have in JBuilder.
> > Thanks
> >> Hi,
> >> dialog
> >> installed.
> >> > Eclipse
> >> > book.
> >> > I
> >> > on
> >> > version
> >> > Thanks!
Current Time: Sat Oct 25 07:56:21 EDT 2025
Powered by FUDForum. Page generated in 0.04681 seconds
