where are codes generated by WTP tools [message #182923] |
Sun, 19 November 2006 12:56 |
Originally posted by: qyyang79.yahoo.com
Hi all,
After using WTP tools (tried : Creating Top Down Web Service), I'd like to
know:
1) where are the code generated?
2) are they available for axis outside eclipse?
3) it appears that the codes generated are for axis 1.*; where the wtp
tools will be upgraded to work with axis2 1.1 (the latest)
Thanks and appreciated your answers.
Regards.
QY
Re: where are codes generated by WTP tools [message #183855 is a reply to message #183798] |
Thu, 07 December 2006 07:16 |
Zohar Amir Messages: 419 Registered: July 2009 |
Hello Chris,
Looking at the WIKI link you attached, it says that "The target release for
the initial integration work is WTP 2.0", so I checked and found that "WTP
2.0 is based on Eclipse 4.0, which we assume will be released in 2Q2007"
( http://www.eclipse.org/webtools/development/planning/roadmap .html). Is this
true, because "Our target is to complete 3.3 in late June 2007"
( http://www.eclipse.org/eclipse/development/eclipse_project_p lan_3_3.html)?
"Chris Brealey" <cbrealey@ca.ibm.com> wrote in message
news:4576D3F0.32C25BFD@ca.ibm.com...
> QY,
> 1) with the help of the Axis emitters, the Web service wizard generates
> the
> Java code for the service under the source folder of your Web project (by
> default, "src"). The deploy.wsdd and undeploy.wsdd XML files are generated
> under web-inf. The Axis servlet is inserted into web-inf/web.xml. Finally,
> the
> jars that make up the Axis runtime are copied into web-inf/lib.
> 2) The resulting Web project can be exported as a WAR and run as-is on any
> Web
> application server, such as Tomcat, outside of the scope of Eclipse.
> 3) WTP 1.5.2 includes Axis 1.3. We are working on a new set of plugins for
> Axis2 in WTP 2.0 [1].
> [1] http://wiki.eclipse.org/index.php/Axis2_Integration_in_WTP
> Cheers - CB.
> "Q. Yang" wrote:
>> Hi all,
>> to
>> know:
>> Regards.
>> QY
FUDForum. Page generated in 0.04317 seconds
