Home » Eclipse Projects » NatTable » how to add a new row in the filter list, if rows are already filttered.
how to add a new row in the filter list, if rows are already filttered. [message #1164066] Thu, 31 October 2013 08:09 Go to next message
Hi !
I have implemented IFilterStrategy and applying filter on table and it works fine. Now, i have a requirement to add a new row in the filter list. when i add it, as new row does not satisfy the given filtering criteria so it get's added in the main event list but does not get visible.
As filtering criteria is keeping the filter list in the persistent state and reject any other row which fails to satisfy the criteria.
How i can remove that persistence, once the filter is applied ?
(Note: i do not want to remove criteria ,as then all the rows get visible, i only wants to add a new row in the already filtered rows).
One solution in my mind is to apply the filter again after adding a new row and create another matcher which will filter only that row on the base of it's unique id, while rest of the rows will be filtered on the same previous criteria that was before adding a new row. Is it a right approach?, if there is any easy or better solution available then please suggest ?
SD Khan
Re: how to add a new row in the filter list, if rows are already filttered. [message #1164684 is a reply to message #1164066] Thu, 31 October 2013 17:23 Go to previous messageGo to next message
AFAIK the FilterList caches which rows are not filtered. On adding a row the FilterList seems to not get informed and does not update the cached Matcher result.
So I suppose you need to reapply the filter or perform an update on the Matcher to solve your use case.
Greez,
Dirk
Re: how to add a new row in the filter list, if rows are already filttered. [message #1165284 is a reply to message #1164684] Fri, 01 November 2013 03:10 Go to previous messageGo to next message
Yup, right. I am reapplying filter with new criteria (including the previous plus the new) and it is working great.
SD Khan
Re: how to add a new row in the filter list, if rows are already filttered. [message #1798616 is a reply to message #1165284] Wed, 21 November 2018 03:30 Go to previous message
HI,
I am also trying to do the same. But i am going wrong in reapplying the filter, can you please post those lines of code, where you are adding your data and reapplying the filter?
Previous Topic:How to use CellPainterDecorator class
Next Topic:Sorting on large data-set
Current Time: Fri Jun 20 06:40:05 EDT 2025
Powered by FUDForum. Page generated in 0.09852 seconds
