CVS Resource out of sync - but will not allow me to commit - what's up? [message #182319] |
Wed, 13 October 2004 12:39 |
Originally posted by: dakoontz.yahoo.com
I have a Java EAR file that is checked into CVS, after changing it
(rejaring) Eclipse (3.0) & CVS plugin will not allow me to check in the
EAR. It is labled as "1.8 - 1.8 (Binary)" in the Team Sync view. I don't
know what all that is supose to mean - but to me I just want it checked
in. I do a re-sync, I don't see any menu item called "refresh", but
re-syncing does not help.
What am I doing wrong?
Here the error message:
Problem accessing resource: /news/dist/newsService.ear. Resource is out of
sync with the file system: /news/dist/newsService.ear. Perform a Refresh.
org.eclipse.core.internal.resources.ResourceException: Resource is out of
org.eclipse.core.internal.localstore.FileSystemResourceManag er.read(FileSystemResourceManager.java:508)
org.eclipse.core.internal.resources.File.getContents(File.ja va:262)
org.eclipse.core.internal.resources.File.getContents(File.ja va:251)
org.eclipse.team.internal.ccvs.core.resources.EclipseFile.ge tContents(EclipseFile.java:76)
org.eclipse.team.internal.ccvs.core.client.Session.sendFile( Session.java:616)
org.eclipse.team.internal.ccvs.core.client.Session.sendModif ied(Session.java:577)
org.eclipse.team.internal.ccvs.core.client.AbstractStructure Visitor.sendFile(AbstractStructureVisitor.java:191)
org.eclipse.team.internal.ccvs.core.client.ModifiedFileSende r.sendFile(ModifiedFileSender.java:38)
org.eclipse.team.internal.ccvs.core.client.FileStructureVisi tor.visitFile(FileStructureVisitor.java:47)
org.eclipse.team.internal.ccvs.core.resources.EclipseFile.ac cept(EclipseFile.java:147)
org.eclipse.team.internal.ccvs.core.client.AbstractStructure Visitor.visit(AbstractStructureVisitor.java:255)
org.eclipse.team.internal.ccvs.core.client.Commit.sendLocalR esourceState(Commit.java:54)
org.eclipse.team.internal.ccvs.core.client.Command.doExecute (Command.java:408)
org.eclipse.team.internal.ccvs.core.client.Command$1.run(Com mand.java:337)
org.eclipse.team.internal.ccvs.core.resources.EclipseSynchro nizer.run(EclipseSynchronizer.java:1408)
org.eclipse.team.internal.ccvs.core.resources.EclipseResourc e$2.run(EclipseResource.java:268)
org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1673)
org.eclipse.team.internal.ccvs.core.resources.EclipseResourc e.run(EclipseResource.java:265)
org.eclipse.team.internal.ccvs.core.client.Command.execute(C ommand.java:349)
org.eclipse.team.internal.ccvs.core.client.Command.execute(C ommand.java:754)
org.eclipse.team.internal.ccvs.ui.operations.CommitOperation .executeCommand(CommitOperation.java:75)
org.eclipse.team.internal.ccvs.ui.operations.SingleCommandOp eration.execute(SingleCommandOperation.java:46)
org.eclipse.team.internal.ccvs.ui.operations.RepositoryProvi derOperation.execute(RepositoryProviderOperation.java:59)
org.eclipse.team.internal.ccvs.ui.operations.CommitOperation .execute(CommitOperation.java:68)
org.eclipse.team.internal.ccvs.ui.operations.CVSOperation.ru n(CVSOperation.java:84)
org.eclipse.team.internal.ccvs.ui.subscriber.WorkspaceCommit Operation.commit(WorkspaceCommitOperation.java:217)
org.eclipse.team.internal.ccvs.ui.subscriber.WorkspaceCommit Operation.run(WorkspaceCommitOperation.java:210)
org.eclipse.team.internal.ccvs.ui.subscriber.CVSSubscriberOp eration$1.run(CVSSubscriberOperation.java:72)
org.eclipse.team.internal.ccvs.ui.subscriber.CVSSubscriberOp eration.run(CVSSubscriberOperation.java:67)
org.eclipse.team.internal.ui.actions.JobRunnableContext.run( JobRunnableContext.java:159)
org.eclipse.team.internal.ui.actions.JobRunnableContext$3.ru nInWorkspace(JobRunnableContext.java:179)
org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
Re: CVS Resource out of sync - but will not allow me to commit - what's up? [message #182330 is a reply to message #182319] |
Wed, 13 October 2004 12:58 |
The resource has been changed outside of Eclipse and hence it's out of
sync. Select the resource and then
File > Refresh (or press F5).
Dani
Re: CVS Resource out of sync - but will not allow me to commit - what's up? [message #182337 is a reply to message #182330] |
Wed, 13 October 2004 13:02 |
Thanks! - I was trying to work in Team Sync - I had to switch to the Java
perspective to find the "Refresh" context menu.
I'm not sure what Refresh is doing - because the EAR was built by ANT from
within Eclipse's Run menu...
So anyway it works - but you have to switch perspectives to get the job
done, not real cool!
> Dani
Re: CVS Resource out of sync - but will not allow me to commit - what's up? [message #182352 is a reply to message #182337] |
Wed, 13 October 2004 13:37 |
You can specify to refresh resources when running the ant script.
Dani
>>Dani
FUDForum. Page generated in 0.03400 seconds
