| Checking out GEF examples [message #182318] |
Tue, 24 May 2005 00:08  |
Originally posted by: phiferd.gwu.edu
When I check out the GEF shapes example, I get the following error:
"The project was not built since its build path is incomplete. Cannot find
the class file for org.eclipse.swt.widgets.Listener. Fix the build path
then try building this project org.eclipse.gef.examples.shapes."
What am I doing wrong? I have made no modifications to the source. If
anything should work for the complete novice -- shouldn't the examples?
Similar arrors occur for:
org.eclipse.gef.examples.ediagram
org.eclipse.gef.examples.logic
I am using
Eclipse 3.1 M7
GEF 3.1 M6
Dan
| Re: Checking out GEF examples [message #182431 is a reply to message #182318] |
Tue, 24 May 2005 19:31  |
First of all, I am also a newcomer of GEF. Here is how I resloved a problem
which occured when trying Shapes. Though it's not same as yours, I hope the
method would help.
When I use Platform 3.0.2 and GEF 3.1M6, I got problem of "Unable to create
this part due to an internal error. Reason for the
failure: The editor class could not be instantiated. This usually indicates
that the editor's class name was mistyped in plugin.xml." As a newcomer, I
have no idea to look into the source code to figure out the reasons. So I
simply used platform 3.1M7 and GEF 3.1M7. It works well.
Good luck!
Vince
"Dan" <phiferd@gwu.edu> wrote in message
news:f82293d174c39c08c2ce85ac8dea3796$1@www.eclipse.org...
> I am using
> Eclipse 3.1 M7
> GEF 3.1 M6
> Dan
FUDForum. Page generated in 0.61063 seconds
