Home » Archived » BIRT » Appending to SQL Where statement
Appending to SQL Where statement [message #182098] Wed, 02 August 2006 17:42 Go to next message
Originally posted by: svenn.cayenta.com
Is it possible to add to the where clause based on a condition without
creating the whole SQL in a JavaScript method?
That is I have a query in my Data Set object
Select column1, column2....column25 from table where column1 = 'A'
I'm passing a parameter to the report called FLAG.
What I want to do is create a conditional statement such as
If FLAG = "S" Then
SQL = SQL + " column16 = 'SUBMIT'"
Else If FLAG = "P" Then
SQL = SQL + " column16 = 'PENDING'"
Else If FLAG = "A" Then
SQL = SQL + " column25 = 'ACCEPT'"
Else If FLAG = "R" Then
SQL = SQL + " column25 = 'REJECT'"
Re: Appending to SQL Where statement [message #182126 is a reply to message #182098] Wed, 02 August 2006 18:40 Go to previous messageGo to next message
Have you tried using Property Binding? In Data Set Editor's Property Binding
tab defined query text to be
"SELECT .... WHERE ..." +
params["FLAG"] == "S" ? "column16='SUBMIT'" :
params["FLAG"] == "P"? "column16 = 'PENDING'" :
There is also a more creative way to do this. Define the SQL to be
SELECT ... WHERE column1 = 'A'
AND ( ( ? = 'S' AND column16 = 'SUBMIT') OR ( ?='P' AND column16 =
'PENDING') OR ... )
You will end up with a number of data set parameters. Just bind them all to
the same report parameter.
Gary Xue
Actuate Corporation - Product Development
BIRT Committer
"S Venn" <svenn@cayenta.com> wrote in message
news:ca95b1c3ec3990b9624e7edd0efadbab$1@www.eclipse.org...
> If FLAG = "S" Then
Re: Appending to SQL Where statement [message #183500 is a reply to message #182098] Tue, 08 August 2006 15:20 Go to previous messageGo to next message
There is a very easy way to do this. You just build your WHERE clause in
Java and then append it entirely as a single parameter. This works great
and I will append a complete example that does it:
XXX.rptdesign file (excerpt):
Three things to notice in here
1.) Notice how the WHERE_CLAUSE is passed in as a parameter. This
will need to be set in your Java class before you execute the report file.
2.) Notice before the SQL statement I have a line:
<method name="beforeOpen"><![CDATA[this.queryText = this.queryText
+ " " + params["WHERE_CLAUSE"];]]></method>
This line takes the existing query (via its property named
'queryText') and appends the where clause to it.
3.) Notice that I have built my query to accept that the where
clause
will be appended.
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 1.0.1 Build
&lt;20051130-1157></property>
<property name="units">in</property>
<text-property name="displayName">Diagnosis Frequency</text-property>
<parameters>
<scalar-parameter name="WHERE_CLAUSE" id="7">
<property name="valueType">static</property>
<property name="dataType">string</property>
<property name="allowNull">true</property>
<property name="defaultValue">1 = 0</property>
<property name="controlType">text-box</property>
<property name="format">Unformatted</property>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="44">
<property
name="odaDriverClass">com.microsoft.sqlserver.jdbc.SQLServerDriver </property>
<property
name="odaURL">jdbc:sqlserver://localhost:1433;databaseName=FREYA_DB</property>
<property name="odaUser">FREYA</property>
<encrypted-property
name="odaPassword">bWlkZ2FyZDE=</encrypted-property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Diagnosis Code Data Set" id="1200">
<property name="dataSource">Data Source</property>
this.queryText + " " + params["WHERE_CLAUSE"];]]></method>
<property name="queryText">
SELECT * FROM CLAIM WHERE
</property>
</oda-data-set>
</data-sets>
[rest of the file omitted because it has nothing that pertains to this
point.]
Java class that executes the report
protected void renderComponent(IMarkupWriter pWriter, IRequestCycle
pCycle)
pWriter.begin("p");
getHTMLReport(pWriter, pCycle.getListenerParameters());
pWriter.end("p");
private void getHTMLReport(IMarkupWriter pWriter, Object[] pParameters)
ReportEngine engine = ReportEngineFactory.getEngine();
// Run reports, etc.
try
HashMap<String, Object> parameters = new HashMap<String, Object>();
setOutgoingParameters( parameters, pParameters );
IReportRunnable design = getReportSpecification( engine,
(String)pParameters[ 0 ] );
// Create task to run the report and render the report
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
// Set Render context to handle url and image locataions
HTMLRenderContext renderContext = new HTMLRenderContext();
// renderContext.setImageDirectory("image");
HashMap<String, Object> contextMap = new HashMap<String, Object>();
contextMap.put(EngineConstants.APPCONTEXT_HTML_RENDER_CONTEX T,
renderContext);
task.setAppContext(contextMap);
task.setParameterValues(parameters);
populateDatabaseConnectionParameters( design );
// create output stream
ByteArrayOutputStream out = new ByteArrayOutputStream(2048);
// Set rendering options - such as file or stream output,
// output format, whether it is embeddable, etc
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputStream(out);
options.setOutputFormat("html");
task.setRenderOption(options);
// UTF-8
task.run();
pWriter.printRaw( out.toString( "UTF-8" ) );
//printReport(pWriter, engine, report);
catch (Exception e1)
e1.printStackTrace();
// Shut down the engine.
if (engine != null)
// engine.destroy();
private IReportRunnable getReportSpecification( ReportEngine pEngine,
String pFileName ) throws Exception
InputStream stream =
PeReportRenderer.class.getClassLoader().getResourceAsStream( pFileName );
IReportRunnable design = pEngine.openReportDesign( stream );
return design;
Code that builds the WHERE clause and sets it as a parameter
/** This is for the Worksheet_Report.rptdesign */
public void populateParameters1( HashMap<String, Object> pOut, Object[]
pIn )
StringBuffer where = new StringBuffer();
where.append( "\nCLAIM1.DISCRIMINATOR = 'PRO' " );
where.append( "\nAND CLAIM1.CLAIM_STATUS = '" + Identifiable.ACTIVE +
where.append( "\nAND CLAIM1.ANALYSIS_STATUS <> 'NN' " );
where.append( "\nAND CLAIM1.ENTERPRISE_IID = " +
this.getUser().getDefaultEnterpriseID() );
where.append( populateStartAndEndClaimIID( pOut, pIn[ 1 ],
pIn[ 2 ] ) );
/** The following logic is necessary in case we arrived here via the
Claim Edit Screen, which only
* supplies parameters for parms 0, 1, 2 */
if( pIn.length > 3 )
where.append( populateStartAndEndSystemEntryDate( pOut, pIn[ 3
], pIn[ 4 ] ) );
where.append( populateStartAndEndServiceStartDate( pOut, pIn[ 5
], pIn[ 6 ] ) );
where.append( populateStartAndEndBatchEID( pOut, pIn[ 7
], pIn[ 8 ] ) );
where.append( populateStartAndEndPractitionerEID( pOut, pIn[ 9
], pIn[ 10 ] ) );
where.append( populateStartAndEndMedicalRecordNumber( pOut, pIn[ 11
], pIn[ 12 ] ) );
where.append( populateFlags( pOut, pIn[ 17
], pIn[ 18 ], pIn[ 19 ], pIn[ 20 ] ) );
where.append( populateEnvironment( pOut, pIn[ 21
], pIn[ 22 ] ) );
where.append( populateAnalysisType( pOut, pIn[ 26
where.append( populateAccountsList( pOut, pIn ) );
where.append( populatePlansList( pOut, pIn ) );
where.append( populateFlagsList( pOut, pIn ) );
where.append( populateEnterpriseList( pOut, pIn) );
pOut.put( "WHERE_CLAUSE", where.toString() );
Re: Appending to SQL Where statement [message #184924 is a reply to message #183500] Tue, 15 August 2006 03:42 Go to previous message
> clause
> will be appended.
> <parameters>
> </scalar-parameter>
> </parameters> <data-sources>
> <oda-data-source
> id="44">
> <property
> <property
> <encrypted-property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> SELECT * FROM CLAIM WHERE </property>
> </oda-data-set>
> </data-sets>
> point.]
> pCycle)
> { pWriter.begin("p");
> pWriter.end("p");
> try
> report
> renderContext); task.setAppContext(contextMap);
> // UTF-8
> task.run();
> if (engine != null)
> return design;
> pIn )
> pIn[ 2 ] ) );
> via the Claim Edit Screen, which only
> ], pIn[ 4 ] ) ); where.append(
> populateStartAndEndServiceStartDate( pOut, pIn[ 5 ], pIn[ 6 ] ) );
> ], pIn[ 8 ] ) ); where.append(
> populateStartAndEndPractitionerEID( pOut, pIn[ 9 ], pIn[ 10 ] ) );
> ], pIn[ 12 ] ) );
> pIn[ 17 ], pIn[ 18 ], pIn[ 19 ], pIn[ 20 ] ) );
> ], pIn[ 22 ] ) ); where.append(
> populateAnalysisType( pOut, pIn[ 26 ] ) );
> pOut.put( "WHERE_CLAUSE", where.toString() ); }
You can also use conditionals in beforeOpen method. If there is not
another need for java code. You can build the whole query in the
beforeOpen script.
Harun.
Previous Topic:calculate sum of column content
Next Topic:Jconnect to Sybase Adaptive Server Anywhere
Current Time: Thu Nov 06 10:58:46 EST 2025
Powered by FUDForum. Page generated in 0.03476 seconds
