Home » Archived » BIRT » Formating zero number to empty string
Formating zero number to empty string [message #181950] Wed, 02 August 2006 11:04
Originally posted by: pavlov.clockbs.com
Hi to all,
I am used to format mask(code) of type positive;negative;zero
and if you need to show something special or just a space for
the zeroes you are doing it through the mask.
Unfortunately with BIRT 2.0.1 it is not possible.
I know that adding a condition in the field data will do the trick but ...
Is it planned this issue to be resolved or it is a feature I don't know
about?
thank you.
Veselin Pavlov
Previous Topic:Associate Data with a report
Next Topic:BIRT and RAD
Current Time: Sun Nov 09 22:48:50 EST 2025
Powered by FUDForum. Page generated in 0.02808 seconds
