XSD to ECore changing element class [message #1161719] |
Wed, 30 October 2013 00:37 |
Generating a model from a XSD and have used the ecore:name annotation to
successfully change the names of generated ECore classes in types and
attributes, but have no luck doing it for elements.
For example I have an:
<xs:element name="ProgramStatusType" ecore:name="ProgramStatus">
but the generated class comes out:
ProgramStatusTypeType.class
Also note that in the ecore model I see extended metadata like this:
Value ProgramStatusType_._type
Am I using the right annotation in the XSD to change the names of
elements or have I missed something?
thanks for any help,
John
Re: XSD to ECore changing element class [message #1161967 is a reply to message #1161731] |
Wed, 30 October 2013 04:30 |
Thanks Ed, Moving the annotations to the anonymous types does the trick.
On 10/29/2013 07:49 PM, Ed Merks wrote:
> John,
> Comments below.
>> to successfully change the names of generated ECore classes in types
>> and attributes, but have no luck doing it for elements.
> Elements don't map to EClasses so such an annotation would only change
> the name of a feature...
> There must be an anonymous complex type involved so that's where you
> should put the name annotation.
> I imagine it's just not in the right place...
>> John
FUDForum. Page generated in 0.03795 seconds
