greenpages sample getting errors on junit test [message #1161410] |
Tue, 29 October 2013 19:58 |
Brent Jacox Messages: 5 Registered: February 2013 |
I have downloaded the greenpages samples-3.0.0.RC1. When I run a mvn package on the greenpages home I was getting an error about the Log Factory:
T E S T S
Running greenpages.jpa.JpaDirectorySpringContextTests
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.04 sec <<< FAILURE!
Results :
Tests in error:
initializationError(greenpages.jpa.JpaDirectorySpringContextTests): org/apache/commons/logging/LogFactory
So I found another post here that recommended adding another dependency
Now I am getting this error:
T E S T S
Oct 29, 2013 1:53:28 PM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from class path resource [META-INF/spring/module-context.xml]
INFO: Loading XML bean definitions from class path resource [META-INF/spring/test-context.xml]
Oct 29, 2013 1:53:28 PM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFO: Refreshing org.springframework.context.support.GenericApplicationContext@5f08cd64: startup date [Tue Oct 29 13:53:28 MDT 2013]
; root of context hierarchy
Oct 29, 2013 1:53:29 PM org.springframework.beans.factory.support.DefaultSingletonBeanRegistry destroySingletons
INFO: Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@9856ec1: defining beans [org.spr
ingframework.context.weaving.AspectJWeavingEnabler#0,org.springframework.context.config.internalBeanConfigurerAspect,loadTimeWeaver,
entityManagerFactory,transactionManager,org.springframework.context.annotation.internalConfigurationAnnotationProcessor,org.springfr
amework.context.annotation.internalAutowiredAnnotationProcessor,org.springframework.context.annotation.internalRequiredAnnotationPro
cessor,org.springframework.context.annotation.internalCommonAnnotationProcessor,org.springframework.context.annotation.internalPersi
stenceAnnotationProcessor,org.springframework.transaction.config.internalTransactionAspect,org.springframework.dao.annotation.Persis
tenceExceptionTranslationPostProcessor#0,directory,dataSource,greenpages.jpa.TestDataPopulator#0,org.springframework.context.annotat
ion.ConfigurationClassPostProcessor$ImportAwareBeanPostProcessor#0]; root of factory hierarchy
Oct 29, 2013 1:53:29 PM org.springframework.test.context.TestContextManager prepareTestInstance
SEVERE: Caught exception while allowing TestExecutionListener [org.springframework.test.context.support.DependencyInjectionTestExecu
tionListener@452d9a56] to prepare test instance [greenpages.jpa.JpaDirectorySpringContextTests@34efa795]
java.lang.IllegalStateException: Failed to load ApplicationContext
at org.springframework.test.context.TestContext.getApplicationContext(TestContext.java:308)
at org.springframework.test.context.support.DependencyInjectionTestExecutionListener.injectDependencies(DependencyInjectionT
estExecutionListener.java:109)
at org.springframework.test.context.support.DependencyInjectionTestExecutionListener.prepareTestInstance(DependencyInjection
TestExecutionListener.java:75)
at org.springframework.test.context.TestContextManager.prepareTestInstance(TestContextManager.java:321)
at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.createTest(SpringJUnit4ClassRunner.java:220)
at org.springframework.test.context.junit4.SpringJUnit4ClassRunner$1.runReflectiveCall(SpringJUnit4ClassRunner.java:301)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.methodBlock(SpringJUnit4ClassRunner.java:303)
at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.runChild(SpringJUnit4ClassRunner.java:240)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:50)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:193)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:52)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:191)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:42)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:184)
at org.springframework.test.context.junit4.statements.RunBeforeTestClassCallbacks.evaluate(RunBeforeTestClassCallbacks.java:
61)
at org.springframework.test.context.junit4.statements.RunAfterTestClassCallbacks.evaluate(RunAfterTestClassCallbacks.java:70
at org.junit.runners.ParentRunner.run(ParentRunner.java:236)
at org.springframework.test.context.junit4.SpringJUnit4ClassRunner.run(SpringJUnit4ClassRunner.java:180)
at org.apache.maven.surefire.junit4.JUnit4Provider.execute(JUnit4Provider.java:236)
at org.apache.maven.surefire.junit4.JUnit4Provider.executeTestSet(JUnit4Provider.java:134)
at org.apache.maven.surefire.junit4.JUnit4Provider.invoke(JUnit4Provider.java:113)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.apache.maven.surefire.util.ReflectionUtils.invokeMethodWithArray(ReflectionUtils.java:189)
at org.apache.maven.surefire.booter.ProviderFactory$ProviderProxy.invoke(ProviderFactory.java:165)
at org.apache.maven.surefire.booter.ProviderFactory.invokeProvider(ProviderFactory.java:85)
at org.apache.maven.surefire.booter.ForkedBooter.runSuitesInProcess(ForkedBooter.java:103)
at org.apache.maven.surefire.booter.ForkedBooter.main(ForkedBooter.java:74)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.springframework.context.weavi
ng.AspectJWeavingEnabler#0': Initialization of bean failed; nested exception is org.springframework.beans.factory.BeanCreationExcept
ion: Error creating bean with name 'loadTimeWeaver': Initialization of bean failed; nested exception is java.lang.IllegalStateExcept
ion: ClassLoader [sun.misc.Launcher$AppClassLoader] does NOT provide an 'addTransformer(ClassFileTransformer)' method. Specify a cus
tom LoadTimeWeaver or start your Java virtual machine with Spring's agent: -javaagent:org.springframework.instrument.jar
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFact
ory.java:527)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactor
y.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
at org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1097)
at org.springframework.context.support.AbstractApplicationContext.invokeBeanFactoryPostProcessors(AbstractApplicationContext
.java:661)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:446)
at org.springframework.test.context.support.AbstractGenericContextLoader.loadContext(AbstractGenericContextLoader.java:84)
at org.springframework.test.context.support.AbstractGenericContextLoader.loadContext(AbstractGenericContextLoader.java:1)
at org.springframework.test.context.TestContext.loadApplicationContext(TestContext.java:280)
at org.springframework.test.context.TestContext.getApplicationContext(TestContext.java:304)
... 30 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'loadTimeWeaver': Initialization o
f bean failed; nested exception is java.lang.IllegalStateException: ClassLoader [sun.misc.Launcher$AppClassLoader] does NOT provide
an 'addTransformer(ClassFileTransformer)' method. Specify a custom LoadTimeWeaver or start your Java virtual machine with Spring's a
ory.java:527)
y.java:456)
at org.springframework.context.weaving.LoadTimeWeaverAwareProcessor.postProcessBeforeInitialization(LoadTimeWeaverAwareProce
ssor.java:95)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(
AbstractAutowireCapableBeanFactory.java:394)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFa
ctory.java:1448)
ory.java:519)
... 42 more
Caused by: java.lang.IllegalStateException: ClassLoader [sun.misc.Launcher$AppClassLoader] does NOT provide an 'addTransformer(Class
FileTransformer)' method. Specify a custom LoadTimeWeaver or start your Java virtual machine with Spring's agent: -javaagent:org.spr
at org.springframework.context.weaving.DefaultContextLoadTimeWeaver.setBeanClassLoader(DefaultContextLoadTimeWeaver.java:93)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeAwareMethods(AbstractAutowireCapableBe
anFactory.java:1472)
ctory.java:1443)
ory.java:519)
... 51 more
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.767 sec <<< FAILURE!
Results :
Tests in error:
search(greenpages.jpa.JpaDirectorySpringContextTests): Failed to load ApplicationContext
I am running Win7 with JDK1.7.0_25
FUDForum. Page generated in 0.03302 seconds
