| Home » Eclipse Projects » Nebula » How to add events to a cell in Grid
 Goto Forum:|
| How to add events to a cell in Grid [message #17118] | Mon, 27 November 2006 05:42  |  |
| Eclipse User  |  |  |  |  | Originally posted by: swetha.atc.tcs.co.in
 I have created a Grid with 3 columns and added 3 griditems in this way..
 The first column being a text,2nd is a label and the third is text again...
 GridEditor editor = new GridEditor (grid);
 items[i].setText("something");
 label = new Label (grid, SWT.BORDER);
 label.setText("         ");
 label.setBackground(Display.getCurrent().getSystemColor(13)) ;
 label.pack ();
 editor.minimumWidth = label.getSize ().x;
 editor.horizontalAlignment = SWT.LEFT;
 editor.setEditor (label, items[i], 1);
 editor=new GridEditor(grid);
 Text text1 = new Text (grid, SWT.NONE);
 text1.setText("anything");
 editor.grabHorizontal = true;
 editor.setEditor(text1, items[i], 2);
 The first GridItem contains 3 more subItems....added them in another for
 loop as above..
 Now I have 2 problems...
 1.) When i expand the first GridItem ,I am able to see all the subItems in
 all the 3 columns....and if I collapse the tree ,all these subItems are
 hidden...
 but if I resize the shell and do the same..its not working ....
 I mean ,the items in the first column are hidden but those in the second
 and 3rd are not.
 2.)I want a dialog to open when i click on the label in the second column
 I am not able to add listeners to the label..How can i do it???
 Thanks in advance..
 Swetha
| Re: How to add events to a cell in Grid [message #17228 is a reply to message #17118] | Mon, 27 November 2006 11:19   |  |
| Eclipse User  |  |  |  |  | Hi Swetha,
 I'm afraid I don't quite understand what you are trying to say in #1.
 Are you collapsing a tree and the items aren't disappearing?  Or are you
 collapsing a column group and the columns aren't disappearing?  Can you
 attach the full code?
 Re 2.) You can add listeners to the label thats used in the editor.
 There's no reason why you cannot.
 -Chris
 Swetha wrote:
 > Hi
 >             label.setText("         ");
 >             label.pack ();
 > loop as above..
 > in all the 3 columns....and if I collapse the tree ,all these subItems
 > are hidden...
 > and 3rd are not.
 > column ..
 > Thanks in advance..
 > Swetha
| Re: How to add events to a cell in Grid [message #18001 is a reply to message #17228] | Wed, 29 November 2006 01:24   |  |
 sorry for the delay...
 Here is my complete code...
 public class MyGrid
 String col1[]={"First","Second","Third"};
 String col3[]={"1st","2nd","3rd"};
 int width[]={200,30,200};
 GridColumn column = null;
 GridItem item = null;
 GridItem treeItems[] = null;
 GridItem treeItem=null;
 GridEditor gridEditor = null;
 GridColumn[] columns;
 GridItem items[]=null;
 GridItem subItem=null;
 GridItem subItemsArray[] = null;
 Label label=null;
 Grid grid ;
 private ArrayList subItems=new ArrayList();
 public void run()
 Display display=new Display();
 Shell shell=new Shell(display);
 shell.setLayout(new FillLayout());
 color = new Color(shell.getDisplay(), new RGB(0,0, 0));
 createContents(shell);
 shell.pack();
 shell.open();
 while (!shell.isDisposed()) {
 if (!display.readAndDispatch()) {
 display.sleep();
 protected Control createContents(final Shell shell)
 sash_form = new SashForm(shell, SWT.HORIZONTAL | SWT.NULL);
 dlg = new ColorDialog(shell);
 grid = new Grid(sash_form,SWT.BORDER | SWT.V_SCROLL | SWT.H_SCROLL);
 grid.setLinesVisible(false);
 grid.setCellSelectionEnabled(true);
 createGrid(grid);
 grid.setSize(300,300);
 return sash_form;
 public void createGrid(final Grid grid)
 grid.setHeaderVisible(true);
 for(int i=0;i<SIZE;i++)
 column=new GridColumn(grid,SWT.NONE);
 column.setTree(true);
 column.setText("Column"+i);
 column.setWidth(width[i]);
 columns=grid.getColumns();
 columns[1].setText("  ");
 item=new GridItem(grid,SWT.NONE);
 items=grid.getItems();
 subItem=new GridItem(items[0],SWT.NONE);
 subItemsArray=items[0].getItems();
 for(int i=0;i<items.length;i++)
 items[i].setText(col1[i]);
 label.setText("         ");
 label.setBackground(color);
 label.pack ();
 text1.setText(col3[i]);
 public static void main (String [] args)
 new GridExample().run();
 When i run this code...
 1.)Expand the first gridItem,maximize the window and then collapse the
 first griditem...
 2.)Can u give  sample code for adding events when a label in the above
 grid is clicked...
 Swetha
| Re: How to add events to a cell in Grid [message #18040 is a reply to message #18001] | Wed, 29 November 2006 10:02  |  |
| Eclipse User  |  |  |  |  | Re 1.) It appears there is a bug in GridEditor.  It does not update the location of the editors when a tree item is expanded or collapsed.  I've
 entered a new bug for it.  You can CC yourself to the bug to be updated
 when its fixed.
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=166206
 If you have a small amount of tree items, you can manually workaround
 this bug by listening for the expand/collapse event on the parent items
 and calling GridEditor.layout().
 Re 2.) Just add listeners to your label... like:
 label.addListener(SWT.MouseDoubleClick, new Listener()
 public void handleEvent(Event event)
 System.out.println("double clicked");
 -Chris
 Swetha wrote:
 > Hi
 > public class MyGrid {
 >    Label label=null;
 >    Grid grid ;
 >         public void run()
 >         shell.pack();
 >         shell.open();
 >             display.sleep();
 > SWT.H_SCROLL);
 >                 createGrid(grid);
 >         return sash_form;
 >             label.setText("         ");
 >             label.pack ();
 > public static void main (String [] args) {
 > first griditem...
 > grid is clicked...
 > Thanks
 > Swetha
| Re: How to add events to a cell in Grid [message #569203 is a reply to message #17118] | Mon, 27 November 2006 11:19  |  |
 -Chris
 Swetha wrote:
 > Hi
 >             label.setText("         ");
 >             label.pack ();
 > loop as above..
 > are hidden...
 > and 3rd are not.
 > column ..
 > Thanks in advance..
 > Swetha
| Re: How to add events to a cell in Grid [message #569787 is a reply to message #17228] | Wed, 29 November 2006 01:24  |  |
 public class MyGrid
 Label label=null;
 Grid grid ;
 public void run()
 shell.pack();
 shell.open();
 display.sleep();
 createGrid(grid);
 return sash_form;
 label.setText("         ");
 label.pack ();
 first griditem...
 grid is clicked...
 Swetha
| Re: How to add events to a cell in Grid [message #569888 is a reply to message #18001] | Wed, 29 November 2006 10:02  |  |
 when its fixed.
 -Chris
 Swetha wrote:
 > Hi
 >    Label label=null;
 >    Grid grid ;
 >         public void run()
 >         shell.pack();
 >         shell.open();
 >             display.sleep();
 > SWT.H_SCROLL);
 >                 createGrid(grid);
 >         return sash_form;
 >             label.setText("         ");
 >             label.pack ();
 > first griditem...
 > grid is clicked...
 > Thanks
 > Swetha
 Current Time: Fri Oct 31 05:34:41 EDT 2025
 Powered by FUDForum . Page generated in 0.05234 seconds |
