Re: OCL Tuples in pivot [message #1160867 is a reply to message #1159724] |
Tue, 29 October 2013 12:04 |
ModelGeek Mising name Messages: 550 Registered: June 2011 |
I have attached a plugin(developed in Kepler). It is very simple plugin with one package "tupletest1".
It contains file TestTuple.java. In this file an Ecore model is created programmatically consisting of one class. Class has one attribute(name = test, type = Real) and one operation(name=opt, type = Tuple(Real, Real), arguments=none).
The OCL statement for attribute is "let t : Tuple(a:Real , b:Real) = opt() in t.a*4" and the OCL statement for operation is "let t : Tuple(a:Real, b:Real) = Tuple{a=2, b=2} in t"
The class TestTuple is instantiated in class View.java(simple view onCreate instantiation for TestTuple is performed).
When i try to evaluate attribute using setting delegates then i get the following exception
org.eclipse.ocl.common.internal.delegate.OCLDelegateException: OCL evaluation result of 'temp::TestClass.test' is invalid
Do you have any clue wht tuple is problematic in the given code.
Cheers
at org.eclipse.ocl.examples.pivot.delegate.OCLSettingDelegate.get(OCLSettingDelegate.java:81)
at org.eclipse.emf.ecore.util.BasicSettingDelegate$Stateless.dynamicGet(BasicSettingDelegate.java:185)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1027)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1011)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1003)
at tupletest1.TestTuple.useDelegates(TestTuple.java:145)
at tupletest1.View.createPartControl(View.java:72)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:142)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityView.createPartControl(CompatibilityView.java:174)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:323)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:254)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:949)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:633)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:526)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:511)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:61)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:61)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:645)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:97)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:649)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:676)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1042)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at tupletest1.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: org.eclipse.ocl.examples.domain.values.impl.InvalidValueException
at org.eclipse.ocl.examples.pivot.evaluation.EvaluationVisitorImpl.visitLetExp(EvaluationVisitorImpl.java:578)
at org.eclipse.ocl.examples.pivot.internal.impl.LetExpImpl.accept(LetExpImpl.java:454)
at org.eclipse.ocl.examples.pivot.utilities.QueryImpl.evaluate(QueryImpl.java:197)
at org.eclipse.ocl.examples.pivot.delegate.OCLSettingDelegate.get(OCLSettingDelegate.java:72)
... 98 more
Caused by: org.eclipse.ocl.examples.domain.values.impl.InvalidValueException: Failed to evaluate temp::TestClass.opt() :
at org.eclipse.ocl.examples.pivot.evaluation.EvaluationVisitorImpl.visitOperationCallExp(EvaluationVisitorImpl.java:794)
at org.eclipse.ocl.examples.pivot.internal.impl.OperationCallExpImpl.accept(OperationCallExpImpl.java:452)
at org.eclipse.ocl.examples.pivot.evaluation.EvaluationVisitorImpl.visitVariable(EvaluationVisitorImpl.java:934)
at org.eclipse.ocl.examples.pivot.internal.impl.VariableImpl.accept(VariableImpl.java:430)
at org.eclipse.ocl.examples.pivot.evaluation.EvaluationVisitorImpl.visitLetExp(EvaluationVisitorImpl.java:575)
... 101 more
at org.eclipse.ocl.examples.pivot.ecore.EObjectOperation.evaluate(EObjectOperation.java:79)
at org.eclipse.ocl.examples.pivot.evaluation.EvaluationVisitorImpl.visitOperationCallExp(EvaluationVisitorImpl.java:701)
... 105 more
[Updated on: Tue, 29 October 2013 12:05] Report message to a moderator
Re: OCL Tuples in pivot [message #1162198 is a reply to message #1160867] |
Wed, 30 October 2013 08:08 |
Ed Willink Messages: 7670 Registered: July 2009 |
You didn't specify how to run your code; Opening a Perspective named
Perspective is a very odd approach.
I have no idea why you are doing such low level model creation. It is
incredibly hard, but if you're going to ignore the higher level aids you
should expect to debug your own problems.
If you added a
Diagnostician.INSTANCE.validate(modelPackage);
you would have noticed a couple of
The feature 'eType' of
'org.eclipse.emf.ecore.impl.EOperationImpl@11db0bc{test.ecore#//TestClass/opt}'
contains a dangling reference
'org.eclipse.ocl.ecore.impl.TupleTypeImpl@129751d{#//}'
The feature 'eClassifier' of
'org.eclipse.emf.ecore.impl.EGenericTypeImpl@c7c79e{test.ecore#//TestClass/opt/@eGenericType}'
Once you fix those, you will notice that your tuple parts are unnamed,
causing the operation lookup failure and so the eventual failure.
When writing very complicated stupid code expect the problem to be in
your code so debug it properly.
Now go back to your original messages and ask yourself how anyone could
have answered your question sensibly.
Ed Willink
On 29/10/2013 13:04, ModelGeek Mising name wrote:
> I have attached a plugin. It is very simple plugin with one package "tupletest1".
> Cheers
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> ... 98 more
> ... 101 more
> ... 105 more
FUDForum. Page generated in 0.05143 seconds
