Home » Language IDEs » Java Development Tools (JDT) » JDK 1.5 source compliance
JDK 1.5 source compliance [message #180546] Thu, 30 September 2004 17:27 Go to next message
Originally posted by: spam.scientifik.com
On a previous install of Eclipse 3.0.1 w/ the JDK 1.5.0 I was able to set
the source compliance to 1.5 in the Java->Compiler section of the
Preferences dialog....now I'm limited to 1.4, even though I'm only using
1.5 and that is the JDK set for use in Eclipse, not 1.4.
How can I fix this?
Re: JDK 1.5 source compliance [message #180554 is a reply to message #180546] Thu, 30 September 2004 17:50 Go to previous messageGo to next message
> How can I fix this?
Use one of the 3.1 integration build. If you had the 1.5 compliance, you
installed the cheetah plugin.
There is no more Cheetah update. It has been merged into the HEAD stream
(3.1).
Olivier
Re: JDK 1.5 source compliance [message #180598 is a reply to message #180554] Thu, 30 September 2004 20:16 Go to previous messageGo to next message
> > How can I fix this?
> (3.1).
> Olivier
Does the Visual Editor work well w/ 3.1? I did have the 3.1 build that
Gentoo has in Portage but I found that some of my plugins were acting
strange.
Re: JDK 1.5 source compliance [message #180614 is a reply to message #180598] Fri, 01 October 2004 03:19 Go to previous messageGo to next message
"zambizzi" <spam@scientifik.com> wrote in message
news:cji7lh$5sm$1@eclipse.org...
> > zambizzi a
Re: JDK 1.5 source compliance [message #183836 is a reply to message #180554] Tue, 19 October 2004 00:37 Go to previous message
Shouldn't the Cheetah page be updated to reflect this?
Gregory Guthrie
guthrie@mum.edu
"Olivier Thomann" <olivier_thomannNOSPAM@ca.ibm.com> wrote in message
news:cjhuq2$p02$1@eclipse.org...
> zambizzi a
Previous Topic:in-live codegeneration for Java
Next Topic:Syntax Highlighted Javascript
Current Time: Sun Nov 09 12:39:40 EST 2025
Powered by FUDForum. Page generated in 0.04080 seconds
