Examples [message #1154419] |
Fri, 25 October 2013 07:23 |
Jan Koehnlein Messages: 760 Registered: July 2009 Location: Hamburg |
is there any example project to play around with?
Jan
Get professional support from the Xtext committers at www.typefox.io
Re: Examples [message #1154853 is a reply to message #1154419] |
Fri, 25 October 2013 13:56 |
Le 25/10/2013 09:23, Jan Koehnlein a écrit :
Hi.
There are many examples that work with the pre-Sirius version of the
code, which was code-named Viewpoint and available as part of Obeo
Designer [1]. If that's OK for you, you can get an evaluation version of
Obeo Designer (time-limited, but with no feature restriction) and follow
the included "Getting Started" guide. You can also find example modelers
at [2].
If you want to use Sirius itself (same code, but we know there are still
some glitches left from the large-scale renaming) you can get the latest
nightly from [3] and the latest version of EcoreTools [4] which is being
rewritten to use Sirius.
If you go to EclipseCon next week, we would be happy to give you a demo
and answer any questions there; just ask at the Sirius booth. There will
also be a BOF session on wednesday where we will help particpants create
their first Sirius-based modeler.
Thanks for you interest and don't hesitate if you need more details.
Pierre-Charles David
[1] http://www.obeodesigner.com/
[2] http://www.obeonetwork.com/
[3] http://download.eclipse.org/sirius/updates/nightly/0.9
[4] http://wiki.eclipse.org/index.php/Ecore_Tools
Pierre-Charles David - Obeo
Re: Examples [message #1201099 is a reply to message #1200859] |
Thu, 21 November 2013 15:21 |
Le 21/11/2013 13:56, Nawel Amok a écrit :
> hello,
hello,
> i am trying the "Basic Family" tutorial in Obeodesigner, to be more
> familiar with meta-modeling... to work after on sirius
> but i am blocked in the "add a style to the node" section (i am using my
> own ecore model) in this step: (i am for this step in runtime as adviced)
> To test this first diagram, right-click in the Model Explorer view on
> the Modeling project and select the menu Viewpoint Selection. You should
> see the new viewpoint Basic Family Design. You must activate this
> viewpoint to be able to create the representations which are defined by
> this viewpoint.
> when i right-click i do not find the menu Viewpoint Selection ! should
> any specific file be selected ?
Could you please clarify:
* What "Model File Extension" have you set for your Viewpoint?
* Is there a semantic model with this extension in your Modeling Project?
> Thanks in advance,
> Nawel
Laurent
Laurent Redor - Obeo
Re: Examples [message #1202701 is a reply to message #1201363] |
Fri, 22 November 2013 09:18 |
In the previous mail you say
> i am using my own ecore model
This file is a family ecore file or other one?
In the runtime you should have an ecore file (not a .odesign file) in
your Modeling Project.
* What "Model File Extension" have you set for your Viewpoint in the
..odesign file?
* Add one or more snapshots of yours "Viewpoint Specification Project",
"Modeling Project" and odesign file (if not confidential), to facilitate
the comprehesion of your problem.
Laurent
Le 21/11/2013 19:05, Nawel Amok a écrit :
> hi,
> at run time i created a viewpoint specification project, in the
> description folder there is a .odesign file
> and in the first created project (not in run time) i have no file with
> this extension , there is also no such file in the demo modeling project
> generated in runtime
> hope i've been clear..
> Nawel
Re: Examples [message #1208895 is a reply to message #1207910] |
Mon, 25 November 2013 08:24 |
It's difficult to see what's wrong in your projects. I would like to
propose to you to follow step by step the "Getting Started" guide as
said by Pierre-Charles. And, only after, try to make your own modeler.
Laurent
Le 24/11/2013 22:04, Nawel Amok a écrit :
> hello Laurent,
> Quote:
> no it's not the family ecore file it's my own(just for testing)
> Quote:
> no i haven't any ecore file in runtime..
> here is an snapshot of what i have in runtime :
> https:/
> /drive.google.com/file/d/0BxB67dkOikCSV2ZIc0FkaWhLSWM/edit?usp=sharing
> thank you,
> Nawel
Re: Examples [message #1739787 is a reply to message #1154419] |
Hi.
at [2].
Re: Examples [message #1742026 is a reply to message #1154419] |
Hi.
at [2].
FUDForum. Page generated in 0.04764 seconds
