Re: Setting context for tomcat 5.0 [message #179848 is a reply to message #179825] |
Mon, 25 September 2006 16:15 |
Originally posted by: alan.chandler.logicacmg.com
On Mon, 25 Sep 2006 10:46:40 -0400, Larry Isaacs
<Larry.Isaacs@sas.com> wrote:
>What usually works best is to create a META-INF/context.xml file in the
>"WebContent" portion of your web project. As part of publishing the
>server and its web projects, the child elements of the Context in that
>context.xml file along with most of its attributes will be incorporated
>into the server.xml that Tomcat runs.
Are you saying that WTP is doing the work of taking the contents of
this context.xml and putting it into the server.xml section?
>After adding a web project to the server, modifying the server.xml under
>the Servers project in your workspace also works. However, if you
>remove the web project from the server, that configuration is lost.
>Cheers,
>Larry
>Alan Chandler wrote:
>> I have been conducting some experiments with tomcat 5.0 as to where the
>> webapp context should be stored, other than conf/server.xml
>> It seems that is should be in conf/Catalina/localhost/webappname.xml
>> where webappname is the name of the particular context.
>> How are you supposed to get eclipse to load that up. I tried editing
>> the server config and putting it there, but nothing happened when it
>> started the server.
Re: Setting context for tomcat 5.0 [message #179856 is a reply to message #179848] |
Mon, 25 September 2006 16:21 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
Yes, for each project added to a Tomcat server (i.e. for each project
related Context in the server.xml under the Servers project), if a
META-INF/context.xml exists in the project, its "contents" are included
in the server.xml that gets published to the "conf" directory where
catalina.base points in the launch configuration.
>> Cheers,
>> Larry
>>> started the server.
FUDForum. Page generated in 0.03258 seconds
