Home » Language IDEs » C / C++ IDE (CDT) » change the cpu architecture
change the cpu architecture [message #179636] Tue, 14 November 2006 11:06 Go to next message
hi there,
I want to change the cpu architecture to ARM. I found some cpu
architectures in PE.java, Elf.java & DebugCongiguration.java files but how
to use it, because I want my final output for ARM architecture so for that
I am using ARM specific GNU tools, please tell me what should I do to
solve this?.
And also I am not able to bind libraries to my Managed make C project,
I have tried it from project properties -> C/C++ Build -> Tool Settings
-> GCC C Linker -> Libraries
under this I have tried both the options -l & -L but it gives me error
that "<path> ld: cannot find <file>.a file"
what should I do to solve this?
please help Me to solve both the problems
Thanks in advance
Parag
Re: change the cpu architecture [message #179685 is a reply to message #179636] Tue, 14 November 2006 13:05 Go to previous messageGo to next message
Parag,
One way to do it is to download and install the Eclipse ARM tools from Actel
called SoftConsole.
The other way is a bit harder.
Download the GNU C compiler, Binary tools and GDB from the GNU website.
Recompile them for the ARM processor.
Copy them into your default gcc directory.
Ray
"parag" <paragpvaidya@gmail.com> wrote in message
news:96828e4849eebbb3a66d39b7d4d0d389$1@www.eclipse.org...
> hi there,
> solve this?.
> Settings -> GCC C Linker -> Libraries under this I have tried both the
> Thanks in advance
> Parag
Re: change the cpu architecture [message #179703 is a reply to message #179685] Tue, 14 November 2006 14:03 Go to previous messageGo to next message
Parag,
The wiki at http://wiki.eclipse.org/index.php/CDT/User/FAQ
has agreat deal of info on cross-compilers.
Ray
"Ray Hurst" <raymond.hurst@wdc.com> wrote in message
news:ejd0hg$f9b$1@utils.eclipse.org...
> Parag,
> Actel called SoftConsole.
> Ray
>> hi there,
>> how to use it, because I want my final output for ARM architecture so for
>> that I am using ARM specific GNU tools, please tell me what should I do
>> to solve this?.
>> project,
>> Thanks in advance
>> Parag
Re: change the cpu architecture [message #179734 is a reply to message #179685] Tue, 14 November 2006 16:03 Go to previous messageGo to next message
Parag,
Here is the CDT wiki:
Another option is to build a standard make project and build the makefile
yourself using the compiler tools of your choice.
Ray
message news:ejd0hg$f9b$1@utils.eclipse.org...
> Parag,
> Ray
>> hi there,
>> to solve this?.
>> project,
>> Thanks in advance
>> Parag
Re: change the cpu architecture [message #179758 is a reply to message #179685] Tue, 14 November 2006 23:54 Go to previous messageGo to next message
thanks for reply.
But I am using ARM sepcific GNU tools. Still it's not working.
please help me.
parag
Re: change the cpu architecture [message #179813 is a reply to message #179636] Wed, 15 November 2006 07:16 Go to previous messageGo to next message
Could you give an e.g. of what you tried for -l & -L ?
BTW, -L is used to specify the library path, & -l denotes the library name,
so you might need to give both.
Delicia.
Re: change the cpu architecture [message #179884 is a reply to message #179636] Wed, 15 November 2006 13:48 Go to previous message
Parag,
Check the news subject "C/C++ project problem by Mats Blide" topic and see
if it answers your questions.
There was enough info there to tell me how to use a cross-compiler.
I am currently using Eclipse for an ARM development myself and use it to
look at the binaries.
I haven't tried compiling it yet as we use an ARM compiler tool set.
The information provided by Derek Morris allows me to make the required
changes to use our compiler.
Ray
> hi there,
> solve this?.
> Thanks in advance
> Parag
Previous Topic:C/C++ project problem
Next Topic:Only CDT not JDT
Current Time: Sun Nov 09 11:22:25 EST 2025
Powered by FUDForum. Page generated in 0.04703 seconds
