Home » Modeling » Papyrus » UML model to SysML model(Change/migrate model with state machines from UML to SysML model)
UML model to SysML model [message #1153503] Thu, 24 October 2013 13:02 Go to next message
Is there an easy way to migrate a model that was started as an Papyrus UML model into a SysML model?
We have models with complex state machines as UML models. Now, these models shall be extended with requirements information, which would work best in a SysML requirements diagram/table.
I'm thankful for any hints.
Rupert
Re: UML model to SysML model [message #1153510 is a reply to message #1153503] Thu, 24 October 2013 13:10 Go to previous messageGo to next message
Hi Rupert,
Simply apply the SysML Profile to your model. After that, you will be able to create pure SysML Diagrams/Tables (e.g. Requirement diagram/table). You will also be able to create standard UML diagrams (With or without SysML elements).
Camille
Re: UML model to SysML model [message #1153528 is a reply to message #1153510] Thu, 24 October 2013 13:24 Go to previous messageGo to next message
Hi Camille,
thanks for the help.
Dumb mistake on my side - I tried what you suggested before asking, but only applied the SysML::Requirements profile, not the SysML base profile.
best
Rupert
Re: UML model to SysML model [message #1844901 is a reply to message #1153503] Wed, 29 September 2021 06:06 Go to previous message
The only maybe not so obvious thing that you would also need to do is "Switch Architecture Context...". Otherwise you are stuck with the Palette and diagram types from the UML Architecture Context.
Previous Topic:Fail - papyrus-robotics-2021-03 #726
Next Topic:Papyrus Software Designer 5.2 Documentation gone?
Current Time: Fri Nov 07 13:38:46 EST 2025
Powered by FUDForum. Page generated in 0.04256 seconds
