Re: printing problem [message #179357 is a reply to message #179316] |
Tue, 26 April 2005 17:25 |
If you downloaded that build, you should have also downloaded Eclipse M6
since that is listed under REQUIREMENTS for that GEF build. There are many
plug-ins which are now distributed as JARs in M6. The runtime has supported
this for a while.
"Sapna George" <sgeorge@vt.edu> wrote in message
news:a8f4fee36488eec5b82a27dd42026f14$1@www.eclipse.org...
>I downloaded GEF-ALL-I20050421.zip (hopefully this is the build you meant)
>and noticed that the plugin zip structure has changed! Now the draw2d and
>gef jar files are directly under eclipse/plugins directory rather than
>under eclipse/plugins/org.eclipse.gef_3.1.0. So, how will my plugin now
>find GEF?
> Is there a document somewhere that explains this new structure and the
> modifications we need to make to our plugin.xml?
> thanks again,
> Sapna
Re: printing problem [message #179903 is a reply to message #179735] |
Mon, 02 May 2005 03:29 |
Sorry, but 3.1M6 < 0421. Please try a more recent Eclipse build.
> Nope. Still no luck. I got Eclipse 3.1M6 and GEF 3.1M6. The icon does not
> "Pratik Shah" <ppshah@us.ibm.com> wrote in message
>> No, I meant *Eclipse* build *greater than* 0421. Look at the last post
>> of
>> the bug I linked you to.
Re: printing problem [message #180402 is a reply to message #180381] |
Wed, 04 May 2005 22:27 |
Pratik Shah Messages: 1077 Registered: July 2009 |
Sapna, not being able to reopen does not prevent you from posting to that
bug report. You should CC yourself to it, describe your problem and provide
the icon and the SWT folks will reopen the bug if your problem's genuine.
However, if I were you, I'd check your setup again. I just tried their
snippet with your icon and 0502 build, and it worked just fine.
news:d5bc5q$8qa$1@news.eclipse.org...
> The webmaster gave me this answer:
> Hello Sapna,
> You need to address the following email to the committers of the
> project, they are the only ones that can reopen this bug.
> Thanks
> Regards
> Sujay
> I'm attaching the gif file to this post. Can you reopen the bug?
> Sapna
> news:d58m1i$20r$1@news.eclipse.org...
> > Could be. Make sure you're logged in and if you still don't see the
> option,
> > try CCing yourself on that bug report. Ask the eclipse webmaster if the
> > problem persists.
> > news:02817f2eeed1f3b31586a646c078bf62$1@www.eclipse.org...
> > > For this bug (28766), i see only 1 option: Leave as RESOVED FIXED. No
> > > reopen option like in some other bugs i have seen. Is my account
> 'special'
> > > (low previleges, maybe)?
Re: printing problem [message #180509 is a reply to message #180469] |
Fri, 06 May 2005 13:16 |
It could be specific to the printer driver that you have.
(go hoos!;-)
news:b62a53a6f5d7e32fef0e71bbe60ef721$1@www.eclipse.org...
> thanks for your response. I'll try to send the bug report.
> But, I'm clueless as to what 'setup' i should check as far as the image is
> concerned. If it's working fine with you, obviously i'm doing something
> wrong!
> sapna
FUDForum. Page generated in 0.04677 seconds
