How to implement Save As for our Part. [message #1151184] |
Wed, 23 October 2013 07:19 |
Hi *,
I'm creating E4 RCP application in that I have one part. I want to implement "Save As" functionality for my Part As it is implemented for Editors (Like:Java file Editor).
Requirements:
1. When user click on my part "Save As" option should be enable.
2. When user click on "Save As" option my code should run so that I can do what I want.
So my question is for this what should I do, is I have to implement any extension point or any this else. ?
Thanks & regards,
Sumit Singh
Re: How to implement Save As for our Part. [message #1181230 is a reply to message #1180902] |
Mon, 11 November 2013 13:15 |
What do you mean 'will not work for other source file'? The Save as ... is the same for both cases. Just dump the contents of the editor into a disk file. Also if you have Eclipse editors yours is likely not a pure Eclipse 4 RCP application. If you're doing a mix of 3.x and 4.x things are different.
FUDForum. Page generated in 0.03856 seconds
