Home » Archived » XML Schema Definition (XSD) » Creating a sample XML instance from a XSD Schema
Creating a sample XML instance from a XSD Schema [message #16893] Wed, 02 April 2003 14:26 Go to next message
In my ongoing project, one of my challenges is to create a sample XML from
the XSD Schema and populate the XML document. Lets say I have saved the
XSD Schema in a .xsd file, are there any API which would let me create a
sample XML Document out of it. I found a xmlgen.jar library provided by
SUN (SUN XML GENERATOR) but its quite useless when applied to the XSD
models. Any ideas or thoughts would be much appreciated..?
thanks for your help
kaunteya
Re: Creating a sample XML instance from a XSD Schema [message #16922 is a reply to message #16893] Wed, 02 April 2003 14:53 Go to previous message
kaunteya bhattacharya wrote:
On this note.. I was curious if it would be feasible(or smart) to use JAXB
to do this for you. What if I convert the XML Schemas into java objects,
and then instantiate these java classes and populate them?
Further, I can serialize them into a XML document.
Does that sound feasible??
> Hello,
> kaunteya
Re: Creating a sample XML instance from a XSD Schema [message #567077 is a reply to message #16893] Wed, 02 April 2003 14:53 Go to previous message
> Hello,
> kaunteya
Previous Topic:Creating a sample XML instance from a XSD Schema
Next Topic:Null Pointer Excp when calling validate()
Current Time: Thu Aug 21 16:06:28 EDT 2025
Powered by FUDForum. Page generated in 0.03836 seconds
