Displaying multiple resources in editor area [message #178701] |
Thu, 21 April 2005 15:21 |
Originally posted by: sbelgaon.progress.com
All,
I would like to display different resources in 2 section of an editor (as
opposed to the conventional tab approach for all resources - each resource
in a tab of editor) . In the top section I would like to display resources
that use graphical editor. In the botton section I would like to display
text resource editors.
If there are multiple resources that need graphical editor then I want
them to be tabbed but in the top section. Similarly if there are multiple
resources that need text editor then I want them to be tabbed but in the
bottom section.
e.g. I have seen similar examples for modeling tools where the graphical
model is displayed at the top (resource e.g - a XMI resource) and the
botton section displays the generated source from the model (resource e.g.
- .java files etc..)
Any help on how to do this is appreciated.
Sunil.
Re: Displaying multiple resources in editor area [message #178861 is a reply to message #178701] |
Fri, 22 April 2005 20:02 |
Reusing the Java editor is going to be very difficult. See bug 46207.
"Sunil Belgaonkar" <sbelgaon@progress.com> wrote in message
news:1114fe2fe21235bec0b6d11b9686f0ad$1@www.eclipse.org...
> All,
> bottom section.
> e.g. - .java files etc..)
> Regards,
> Sunil.
Re: Displaying multiple resources in editor area [message #180154 is a reply to message #178759] |
Tue, 03 May 2005 19:26 |
Pratik Shah wrote:
> All Eclipse users can already do this manually. You can split the editor
> area by dragging the editors.
Can this be done using an API?
> If you want two different views of the same file visible at the same time
> (kinda like a split view), look at how VEP does that.
> http://www.eclipse.org/vep
I am looking to do option 1 above.
>> All,
>> bottom section.
>> Regards,
>> Sunil.
FUDForum. Page generated in 0.03302 seconds
